Android Lurker
Samsung Galaxy Note GT-N7000 Home WiFi Problem
Hi ALL,
I have the same problem over my Samsung Note 16GB .. I was happy to have this gadget but I was disappointed as it can connect to my wifi at home but when login into Facebook etc etc web it just do not load it but once i off reopen again it works just 1 page then same problem again... happen I have called to Samsung Malaysia (Mr RAJ) the Samsung Mobile section technical department to solve my problem as he give me all detail like this:
1)type in *#526# ( is to reset the wifi setting or reload the devices) if it does not works then try the below way.(2)
2) Reset to Factory default (I have done it)
3) Ask me goto market place download a software called FXR WiFi Fix and Rescue .
4) Have installed and run the program.
But still same problem can't works... so i called him back but He never replay my call (Samsung Malaysia)
I was so disappoint about it could anyone knew what the problem like to be?
As I connected to my mobile hotspot (hardware wifi) it work prefect..
So I would like to tell you it is not the router problem have asked the telecom service centre check it out and changed to a DLINK router but as my Samsung Galaxy ACE works well and all my Apple Iphone 3 , 4 , 4s and Ipad2 works all well .
The Samsung Galaxy Note GT-N7000 and my Samsung Galaxy Y does not work well on my wifi could anyone help me out...
it seem like Samsung just wanted to have sale not sale after service at all... it is very disappointed as now is the 3rd week now still could not solved the problem.
Thanks..
P/S The Telecom company ask me to ask SAMSUNG about this matters it is not the router or the fibre optic line problem.
02-15-2012 09:42 AM
# ADS
Super Moderator
Try changing the encryption on your router to wep or use a different channel.
Android Lurker
Hi, im new with android device, i have the same problem with samsung galaxy note, is your problem fix already? please i would be happy to know. thanks
Android Lurker
guys, i found this one in google play, and i think it works like a charm, here's the app FXR WiFi fix and rescue
