Help Needed, PLEASE
This is a discussion on Help Needed, PLEASE within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Where can I find out all about what my tablets "PRODUCT SPECIFICATIONS" That are listed in the user manual mean?...
Like Tree2Likes
  • 1 Post By furbearingmammal
Thread: Help Needed, PLEASE
    Android Lurker vpharr13's Avatar
    Mar 2012
    Question Help Needed, PLEASE
    197 times
    FurryVarmint
    What tablet do you have? I might be able to explain some of the "specs" to you that you have questions about. I plan on heading to bed very shortly (it's 4AM here), but I can answer questions tomorrow and other users/staff may be along to help you out in my absence.
    vpharr13 likes this.
    DO NOT WRITE IN THIS SPACE
    Mar 2012
    Cool
    I have a CRAIG CMP738B tablet.
    *PRODUCT SPECIFICATIONS*
    OPERATING SYSTEM- Android 2.2
    PROCESSING SPEED- 800 MHz
    MEMORY/RAM- 256 MB
    DISPLAY RESOLUTION- 800 x 480 PIXELS
    G SENSOR- YES
    WIRELESS INTERFACE- WiFi 802.11b/g
    BROWSER- WEB BROWSER
    Thank you Very much!
    197 times
    FurryVarmint
    Okay, here's what the specs mean:
    Operating System is FroYo, or Android 2.2. It's an older version but it's fairly lightweight. There may be an update for your tablet, there may not be, but if not there may be a ROM you could install. This would require rooting your tablet and voiding the warranty, though.
    You have an 800MHz CPU. This isn't good, but depending on the screen size it's not that bad. It just means it may not play games very well. For comparison the first Motorola Droid shipped with a 550 (later upgraded to 600) MHz CPU.
    RAM is severely limited at 256MB. It's enough for FroYo, but Gingerbread (Android 2.3 and all the improvements it has) may bog the tablet down. You will want to reboot the tablet at least once a day for maximum performance.
    You have a screen resolution of 800x480. This isn't very sharp, but it should suffice. The aforementioned Droid phone had a screen resolution slightly higher and a screen size of 3.7 inches, for comparison.
    You have a gravity sensor, so you can play games that require one.
    You have a Wi-Fi network compatibility of B and G protocols. G is 54Mbps, and was the standard for many years. Most wireless networks are on the G standard. You should have little to no problems connecting to more Wi-fi hotspots you'll encounter in the wild.
    The tablet has a web browser, probably the stock Android browser. You may want to stick with it, you may want to replace it, that's personal choice.
    I hope this helped!
    Mar 2012
    Thanks a ton! That did really help me out ALOT. Thank you very much, you broke it down in terms that I can actually understand and work with. Your a life saver! Thanks again
    197 times
    FurryVarmint
    Awww, shucks.
    Mar 2012
    LOL, Are you familiar with the app MX Video Player? I was looking for a better video player and someone recommended that one to me. What do you think?
  1. Replies: 0
    Last Post: 10-13-2011, 01:57 AM
  2. ATT Microcell needed
    By WERA689 in forum Android Hardware Wanted
    Last Post: 09-17-2011, 01:48 AM
  3. Help needed
    By kettdoc in forum Android Forum
    Last Post: 07-13-2011, 11:31 AM
  4. Urjent help needed
    By paru155 in forum Android Forum
    Last Post: 07-09-2011, 02:00 PM
  5. Needed: Hurricane App
    By Dolfan0925 in forum LG Ally Apps
    Last Post: 09-17-2010, 08:49 AM
android 2.3 on craig cmp738b
can i upgrade my craig cmp738b to gingerbread
change operating system of craig cmp738b tablet
cmp738b detected as android phone
cmp738b gingerbread update.img
cmp738b specs
craig cmp738b gingerbread update
craig cmp738b replaceing the screen
craig cmp738b root 2012
craig cmp738b screen replacement
craig cmp738b specs
craig cmp738b upgrade gingerbread
craig tablet cmp738b manual
dolfan0925 forum posting
install gingerbread on cmp738b
