Galaxy S3 Media Volume Stuck on Mute
This is a discussion on Galaxy S3 Media Volume Stuck on Mute within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Welcome. Sent from my DROID RAZR HD using Xparent Cyan Tapatalk 2...
Results 11 to 20 of 21
Thread: Galaxy S3 Media Volume Stuck on Mute
    Super Moderator GoCliffGo05's Avatar
    Nov 2012
    Maryland, U.S.
    55 times
    GoCliffGo
    Re: Galaxy S3 Media Volume Stuck on Mute
    Welcome.
    Rescue Squad grenefroggie's Avatar
    Apr 2012
    50 times
    I have a Galaxy S III on AT&T (SGH-I747) running AOKP JB Milestone 1 (4.1.2).
    I keep my phone on vibrate almost all the time. I find notifications to be rather disturbing in general.
    My phone vibrates whenever I get a notification. And when I do turn the volume up, I can hear them all. However, when I open Pandora, whether on vibrate, silent or with sound, I have to hit the volume down button twice and then volume up twice before it will play. Kind of a weird quirk, but it could be because of the custom ROM or the app. I am not sure, but it is the only app that has this issue.
    Food for thought, hopefully it might help someone else.
    Android Lurker TUMBINO's Avatar
    Dec 2012
    Quote Originally Posted by crewonizuka View Post
    I was having the same issue and its not because of any specific app. If you mute the volume in an app or game it will take control of the volume (I.e. for me it was tiny tower). The solution: you can either open the app you last turned the volume down on and turn it up again or if you dont know which one it is just go to task manager (long press home button then press task manager) and end all active apps, then adjust the volume. Hope this helps
    That did the trick CREWONIZUKA. Thanks. Now I can continue my work.
    Android Lurker emoore81's Avatar
    Jan 2013
    I was experiencing the same thing on my galaxy s3. Turns out it was "the chive" app that was doing it. I uninstalled it and havent had the problem again.
    Apr 2012
    50 times
    No one, for any reason, should have to uninstall theChive from their phone!!!
    KCCO!
    Tap'd from my 747 roc'n AOKP M1!!
    Android Lurker JoeLouie's Avatar
    Feb 2013
    I was just having the same problem, and the Chive app was the culprit. I just force closed it, and everything is great now. No need to uninstall it.
    KCCO, indeed!
    Android Lurker mariony36's Avatar
    Mar 2013
    All I did wad hold down the home button and pressed the trash can to clear all task then I held the button down again and pressed the pie chart and clear memory. This should help.
    Quote Originally Posted by Sterling View Post
    Hey just wondering if anyone has had this problem or knows what to do. Basically when I turn down my ringer volume all the way so that it's on mute or vibrate, that mutes my media volume as well. That's great, except that even when I turn my ringer volume back up, my media volume is stuck muted. When I'm on the basic volume menu, with all three volume options, I can slide the media volume to the left or right but the line going through it indicating that it's muted won't go away. When I'm actually on some form of media, the volume stays down at zero and won't move. It fixes it when I turn the phone off and on, but that's annoying as hell. Wondering whether this is something that somebody else has experienced? Here's the apps I downloaded prior to when this happened, in case it's one of these that could be causing the problem.
    Facebook
    Pandora
    Flow Free
    Zynga Poker
    IMDb
    Tiny Tower
    doubleTwist
    Spotify
    Chess Free
    iFunny
    Angry Birds Space
    Also, if no one else is having this problem, which is kind of how it seems right now, should I assume that it's just my own device and take it to the Sprint store?
    Android Lurker qwerty's Avatar
    May 2013
    This works, thank you!
    Android Lurker tigers's Avatar
    Nov 2013
    omg this worked, thank you
    Android Lurker augmentedaphid's Avatar
    Jun 2014
    Just hold down the home button, tap the pie graph on the bottom left and clear ram. Worked for me when my volume wouldn't turn up
  1. Help with Media Volume?
    By JesterYO in forum Samsung Galaxy S2 AT&T
    Last Post: 11-11-2012, 05:03 PM
  2. Replies: 0
    Last Post: 11-28-2011, 10:11 AM
  3. Replies: 0
    Last Post: 11-21-2011, 12:09 PM
  4. Media Volume control
    By Larry3961 in forum LG Ally
    Last Post: 06-30-2011, 06:11 AM
  5. Ringer/media volume switch changes
    By sherongb in forum LG Ally
    Last Post: 04-02-2011, 08:46 AM
audio stuck on mute galaxy note 3
galaxy 3 has no media player volume
galaxy s3 media sound not working
how to unmute a samsung galaxy a3
hw to unmute a3
media sound not working on galaxy s3
media volume not working s3
my galaxy s3 volume won't turn up
my samsung wont let me turn on the volume
samsung galaxy s3 can't turn volume up
samsung galaxy s3 media sound not working
samsung galaxy s3 no media sound
samsung s3 media sound not working
unmute media volume android
why media is mute in samsung
