CDMA Flashing Help
This is a discussion on CDMA Flashing Help within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; Hi my nexus s 4g has bad esn now and I need help flashing my phone from sprint to cricket. I look on YouTube but ...
Thread: CDMA Flashing Help
    Android Jr Member Dnay12's Avatar
    Feb 2012
    North Las Vegas..... Sin city!!!!
    CDMA Flashing Help
    Hi my nexus s 4g has bad esn now and I need help flashing my phone from sprint to cricket. I look on YouTube but not many videos about flashing CDMA. I've tried using software but to complicated. Help please?
    Somewhere on Kamino
    67 times
    Won't work on Cricket. Flashing a rom doesn't change the esn being reported as lost/stolen.
    Feb 2012
    I've seen nexus s 4g on cricket
    Sent from my Nexus S 4G using Android.net
    Somewhere on Kamino
    67 times
    Don't know what to tell you but good luck. And hope it stays working. I have seen multiple people try it and fail. And the phone work for a month or two and then become a paper weight.
    Feb 2012
    Well I'll trust you with this one. Thanks for the advice
    Somewhere on Kamino
    67 times
    It may work for you. My best advice is to ALWAYS call carrier to check esn before buying a phone from someone. If they don't tell you esn then good chance its stolen.
    Android Lurker MaryBrown's Avatar
    Jul 2012
    New york
    CDMA flash software is very compatible with Flash cell phones.This for the people who are very much tech savvy.
    It not only helps in fast message texting but also provides for better connectivity.
  1. GALAXY mini/pop I559 CDMA internet settings
    By chanchalmeister in forum Samsung Galaxy Mini
    Last Post: 09-09-2011, 08:44 AM
  2. Replies: 1
    Last Post: 08-21-2011, 07:12 AM
  3. Tri-Band CDMA Android phones?
    By vSol in forum Android Forum
    Last Post: 06-25-2011, 08:36 AM
  4. Replies: 1
    Last Post: 12-03-2010, 03:49 PM
best flashing software cdma
can you flash a bad esn galaxy s3 to cricket
cdma flash nexus s
cdma flashed phones in las vegas
cdma flashing
cdma flashing forums
cdma flashing software
cdma help 2012
cmda flashing software for androids
flash cdma iphone
nexus cdma flashing software
nexus s 4g to cricket
