Galaxy S2 i9100 Connection Problem
This is a discussion on Galaxy S2 i9100 Connection Problem within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; I have an unlocked android i9100, put a new sim card in but it keeps losing signal with my carrier (no 3g, calls or texts). ...
Thread: Galaxy S2 i9100 Connection Problem
    Android Lurker new2android's Avatar
    Aug 2012
    I have an unlocked android i9100, put a new sim card in but it keeps losing signal with my carrier (no 3g, calls or texts). I have to take out the battery and restart the phone to get it to connect again but the connection does not last long.
    I've tried setting it back to factory settings but it didn't work. Is there anything I can do to fix this issue?
    Thanks!
    Android Lurker SquareWide's Avatar
    Sep 2012
    Hi,
    You could try totally flashing the stock firmware/rom and see if that does the trick.
    I guess the radio (hardware) could have an issue but hopefully not.
  1. Connection Problem or Invalid MMI Code
    By Ashbawn in forum Rescue Squad General
    Last Post: 12-04-2012, 01:12 PM
  2. Galaxy S2 i9100 Connection Problem
    By new2android in forum Rescue Squad Help
    Last Post: 08-10-2012, 03:55 PM
  3. Problem with the Wireless Connection
    By stormbr3ak3r in forum HTC EVO 3D Tech Support
    Last Post: 02-26-2012, 12:32 PM
  4. Bluetooth connection problem
    By crableg in forum Sony Xperia X8
    Last Post: 01-10-2012, 04:22 AM
connection problem invalid mmi code android
connection problem invalid mmi code galaxy s2
connection problem or invalid mmi code
connection problem or invalid mmi code android
connection problem or invalid mmi code fix
connection problem or invalid mmi code galaxy s2
connection problems with galaxy s2
galaxy s2 connection problem
galaxy s2 connection problems
galaxy s3 invalid mmi
i9100 connection problem or invalid mmi code
i9100 connection problems
i9100 mmi code
mmi code galaxy s2
