Droid 4 Using Short Cut Keys When Typing, How to Remove?
This is a discussion on Droid 4 Using Short Cut Keys When Typing, How to Remove? within the Rescue Squad General forums, part of the Android Rescue Squad Support Forum category; I did a lil research and found two things, pop the battery out and that should fix it (but the battery cant come out of ...
Thread: Droid 4 Using Short Cut Keys When Typing, How to Remove?
    Android Lurker rookanga's Avatar
    Oct 2012
    I did a lil research and found two things, pop the battery out and that should fix it (but the battery cant come out of the droid 4, so that wont work) and go to settings then applications then quick launch. The problem is when I go to settings I cant find applications only apps and when I click that I still cant find quick launch even when I hit the all button, ive had my droid 4 for a few months now and this is the first time it has happen and it is very annoying, can anyone help and guide me to where it is, so I can get rid of it
    Android Lurker erroyer's Avatar
    Apr 2013
    Quote Originally Posted by rookanga View Post
    I'm having the exact same problem. I cannot disable Quicklaunch because its simply not there.
    SOMEONE please help us! Having to restart the phone multiple times per day is really bothersome. And this is only one of the several keyboard issues requiring a restart to temporarily eliminate them. If I could disable these app hot keys, that would be a step in the right direction.
    Super Moderator Tears_for_Fears's Avatar
    Apr 2012
    196 times
    Try accessing the keyboard settings and try to find it there. If that doesn't work, you can try an alternative keyboard on the Google Play.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
  1. Galaxy S3 Keyboard Stops Typing
    By majorthink in forum Samsung Galaxy S3
    Last Post: 09-28-2012, 07:39 PM
  2. Short cuts not working
    By GENSCA in forum AT&T
    Last Post: 12-10-2011, 01:46 PM
  3. The short cut for the application does not work
    By GENSCA in forum Samsung Infuse 4G
    Last Post: 12-03-2011, 09:19 PM
  4. Shortcut to switch dictionary on/off while typing
    By nishkarsh_k in forum HTC Desire HD
    Last Post: 11-24-2011, 12:32 AM
  5. HTC Aria Typing Tips
    By dandroid in forum HTC Aria FAQ
    Last Post: 07-22-2010, 03:11 PM
disable quick launch droid 4
droid 4 disable keyboard shortcuts
droid 4 disable quick launch
droid 4 keyboard shortcuts
droid 4 keyboard shortcuts turn off
droid 4 quick launch
droid 4 shortcut keys
droid 4 turn off hot keys
droid 4 turn off quick launch
hot keys on droid 4
how to turn off hotkeys on droid 4
how to turn off shortcut keys on droid 4
turn off hotkeys droid 4
