Star N9776 screen just goes blank during phone calls PLEASE HELP.
This is a discussion on Star N9776 screen just goes blank during phone calls PLEASE HELP. within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Newbie...Please help with Star N9776 6" JB. Phone screen goes black when calling pls help Hi All, I am new to this forum and thought ...
Thread: Star N9776 screen just goes blank during phone calls PLEASE HELP.
    Android Lurker paddyodoors's Avatar
    May 2013
    Unhappy Star N9776 screen just goes blank during phone calls PLEASE HELP.
    Hi All,
    I am new to this forum and thought I would ask for some advice about an issue thats driving me mad.
    I bought a cheap (all I could afford) jelly bean Chinese Star N9776 phone and on the whole have to report its great for the money.
    The only problem is that when I make a call or receive a call the ALS_PS sensor I think turns the screen off and it will not come back on until the call ends.
    I have searched for answers and have found that this is a common problem. One thread suggested that if you enter the boot menu with the volume and power key you can sellect an option to disable this feature.
    However the menu is in Chinese !!
    Please can anyone help me with this or suggest a remedy keeping in mind I am a novice
    Thanks in advance.
    Paddy
    Android Lurker DemoNaija's Avatar
    May 2013
    The 'Als_ps calibration' function in the Display settings will solve this. When in the calibration mode, put the phone to your ear (as if you were taking a call) and hold it still and hit the 'Calibrate' button and let it do its thing for 3 seconds and hit 'OK' after its done. It should solve the issue of the screen blacking out during a call, either incoming or outgoing.
    Hopefully it works.
    May 2013
    Quote Originally Posted by DemoNaija View Post
    Hopefully it works.
    Many thanks. You were correct it sorted out the problem.
    I dont think I was calibrating it correctly to begin with...
  1. G2 Screen Goes Blank
    By scottykarl in forum HTC G2
    Last Post: 04-03-2012, 11:06 AM
  2. Screen goes Blank??
    By dvdman in forum HTC G2
    Last Post: 06-22-2011, 09:15 PM
  3. HELP! Phone asked to update now screen is blank!
    By Hauer in forum Nexus One Tech Issues / Bug Reports
    Last Post: 11-23-2010, 03:55 PM
  4. Phone Screen is black/blank
    By Murkin in forum Nexus One Tech Issues / Bug Reports
    Last Post: 05-03-2010, 12:58 PM
  5. Unable to answer phone calls/Unresponsive screen
    By thechump in forum Nexus One Tech Issues / Bug Reports
    Last Post: 04-15-2010, 02:05 PM
als ps
als ps calibration
als ps calibration android
als ps' calibration
als-ps calibration
als/ps
android als ps calibration
galaxy n 9776
model n9776 phone screen is blank
n9776 menu key
n9776 ps calibration
proper way to do a als ps calibration
star n9776 update
what is als ps calibration
what is als ps calibration android
