I May have deleted my android operating system
This is a discussion on I May have deleted my android operating system within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; This is really embarrassing since taking partial Computer Systems Technician program I don't back up. but I at the time had already rooted my phone ...
Like Tree1Likes
  • 1 Post By herecomesmaggi
Thread: I May have deleted my android operating system
    Android Lurker attilahajzer's Avatar
    Jun 2013
    Canada
    Unhappy I May have deleted my android operating system
    This is really embarrassing since taking partial Computer Systems Technician program I don't back up. but I at the time had already rooted my phone Samsung Galaxy Ace and heard a bunch of talk about roms and updating it. So I decided to try it myself. I was tried a few different roms but they didn't seem to be working and i tried one more rom and it didn't completely finish installing and my cellphone froze and shut down, i turned it on and honestly this is what happens it flashes the Samsung Logo then continues with a cellphone icon 2 dots (connection) then Yellow Triangle exclamation mark the two dots again and a computer monitor or screen.
    The text beneath it says "Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again." But when i connect to my cellphone to my computer and Kies. nothing happens. What do i do, what are my options. I'm trying again because i havn't tried in a few months.
    518 times
    You've just caused a problem to your phone, but I doubt that you deleted the android OS. Problem is, I'm not a technician and I've only HEARD of your phone - never seen one or held one in my hands, so I'm ill equipped to help you. Solution: hang on for awhile and see if some of our more technically inclined staff can give you a hand with the problem.
    Jun 2013
    Canada
    I've tried again and my computer realizes when the phone is plugged in via micro-usb But I'm assuming thats becuase there's power being supplied to that? I'm not sure, anyways i try connecting the phone with kies and after about 10 minutes it just says to restart device and try again
    518 times
    Don't run your battery down too low. One of our people will be around soon.
    Android Jr Member herecomesmaggi's Avatar
    Apr 2013
    India
    7 times
    Quote Originally Posted by attilahajzer View Post
    Enter into recovery by pressing volume and off buttons. Then flash again through adb or kies.
    Recovery Mode Can be Entered Holding Power Button + Middle Button/Home Button + Volume Up Button Simultaneously Until Recovery Mode Appears.
    My advice : Install a custom recovery and flash any rom from sd card that will save u from kies. And other troubles in future.
    For more check this out,
    Link : http://androidlegend.com/how-to-root...xy-ace-s5830i/
    Flowed from Burst !
    UltraDroid likes this.
    Jun 2013
    Canada
    I don't know if this is a problem but It either says Downloading.... forever and nothing advances or RAMDUMP. and the samsung logo centered on the device. no further progress plugged in or not.
    Apr 2013
    India
    7 times
    Dude it will say downloading in handset as it is in upgrade mode you should flash from keis from pc. If it is in warranty ask service center they will fix that in hour or two.
    You just deleted the system files thats why u aren't able to boot in os. Fresh install of os fixes this. Use updating services from kies.
    Flowed from Burst !
  1. Operating System Seems to Use a Lot of Battery
    By notyelfox in forum Samsung Galaxy S2
    Last Post: 08-19-2012, 10:53 PM
  2. HELP! Videos and System Ringtones Got Deleted
    By angiestella in forum Samsung Galaxy Mini
    Last Post: 02-29-2012, 01:17 AM
  3. Replies: 0
    Last Post: 12-04-2011, 01:27 AM
  4. Startup Manager Clean up Your Android System from System Startup
    By afolery in forum Nexus One Application Discussion
    Last Post: 08-25-2010, 12:32 PM
android deleted system
android system deleted
deleted android system
deleted files samsung tablet
how can i delete my operating system android
how to fix operating system deleted android lg
how to put operating system onto samsung note 2 if deleted
how to recover deleted android os
how to recover deleted operating system android
i deleted my android operating system
i deleted my android os
i deleted my android os help
i deleted my android system
i rooted my phone and deleted android system
recover android operating system
