Samsung Galaxy Note 2 Stuck on Boot Logo, Doesn't Start
This is a discussion on Samsung Galaxy Note 2 Stuck on Boot Logo, Doesn't Start within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hello, I have spend about a whole day on this problem without any success. I have a Samsung Galaxy Note 2 which is stuck on ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree1Likes
Thread: Samsung Galaxy Note 2 Stuck on Boot Logo, Doesn't Start
    Android Lurker andy88's Avatar
    Sep 2013
    Hello,
    I have spend about a whole day on this problem without any success. I have a Samsung Galaxy Note 2 which is stuck on its boot screen and doesn't
    proceed any further than that. It shows "Samsung Galaxy Note 2 (GT-N7100)" on the screen. I could only see this after switching the phone on and even after
    restarting the device.
    I had Googled for some help and tried using Odin with so may different Custom ROMs and Samsung's Official Firmware without success. I get error messages
    such as PIT file error on Odin and I have tried downloading (PIT File) which has been also unsuccessful so far. I also tried many different versions of Odin (ranging from 1.x.x to 3.x.x).
    I also cannot get into recovery mode (Pressing Volume Up button, Home, Power).
    I could only enter into the download mode (by pressing the volume down button). I've tried removing battery for 5-10 minutes and restarting again (no success).
    I followed all instructions found online such as installing the Samsung-USB firmware on my Windows machine and I can't see where I could have gone wrong.
    The phone was purchased in Malaysia and (I have used the exact firmware for Malaysia - downloaded from Samsung's website to restore using Odin)
    with no success :-
    Galaxy Note 2 (International) GT-N7100 XME N7100XXDMF2 4.1.2 07.06.2013 1071214
    I hope someone would be able to help me out.
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    Take a look at bootloop categories: http://www.note2forum.com/forum/showthread.php?p=20381
    Look like you have issue with recovery
    Keep us posted
    TapaTalking from Republic™ Of Android
    UltraDroid likes this.
    Sep 2013
    I tried most of the steps described on the site provided by Astrix above with no success. I am using Odin to restore the firmware and it has been difficult as I couldn't access the Recovery mode by (Volume Up, Home, Power) button combo.
    However, I can enter the Download mode (Volume down, Home, Power) combo to download the firmware via Odin but have met issues such as missing PIT. I have a few PIT files (downloaded online) such as the stock version among others - again not working for me. It always gives error such as PIT file not found or it freezes with message (SetupConnection) among others.
    Any other suggestions ? I am really going through a difficult period at the moment as this is my primary phone and I can't get it working. I don't mind losing my data as long as there is a way to reinstall firmware and use is fresh.
    Please help me someone. Please.
    May 2012
    87 times
    It's a bird
    Have you try ONLY recovery.tar file (NOT the whole firmware tar file) flash via PC Odin in PDA?
    Keep us posted
    Sep 2013
    Hi Astrix, I have not tried the "recovery.tar" method.
    How do I obtain the file ? Most importantly what method to flash it via Odin ?
    Would I need to rename anything or place it in a special folder ?
    (Galaxy Note 2 - GT-N7100)
    Sep 2013
    I tried doing what you said earlier and I still get "There is no PIT partition" error on Odin.
    I have installed Kies now. But it's not running as it may interfere with Samsung USB driver.
    <ID:0/004> Added!!
    <ID:0/004> Odin v.3 engine (ID:4)..
    <ID:0/004> File analysis..
    <ID:0/004> SetupConnection..
    <ID:0/004> Initialzation..
    <ID:0/004> Get PIT for mapping..
    <ID:0/004>
    <ID:0/004> There is no PIT partition.
    <OSM> All threads completed. (succeed 0 / failed 1)
    I downloaded the recovery.tar (suitable for my device) from :-
    ClockworkMod ROM Manager - Recoveries
    Goo.im Downloads - Browsing t0ltespr
    May 2012
    87 times
    It's a bird
    Do not run KIES together with Odin
    To install KIES inly to get the drivers that come with KIES. Kill KIES and run only Odin
    What the last firmware you're using?
    - custom rom with what cwm/twrp? or
    - Official rom with official recovery or...etc?
    Have you try flash official recovery only?
    (Where to get, download whole firmware. Open up the zip file and you can find the recovey image)
    Keep us posted
    Sep 2013
    Hi Atrix, Thanks for your support so far.
    I only installed Kies and not running it. I have killed the processes using task manager. Only Odin runs at the moment.
    I downloaded the original firmware from Samsung-update website. The name of the firmware is :-
    N7100XXDMF2_N7100OLBDMD2_N7100DXDMF1_HOME.tar.md5 (about 1.14GB)
    I don't see any recovery file in this firmware file. There's only one single file.
    Any other sources to download from ?
    May 2012
    87 times
    It's a bird
    Try use this firmware and guide. Seem your partition break.
    Here http://forum.xda-developers.com/show...06&postcount=5
    Sep 2013
    I am downloading this now : N7100XXDLJ2_OXA_FACTORY.zip
    What do you propose I do with this file ? Should I look for the recovery file alone ?
  1. Galaxy ACE S5830 Doesn't Boot At All
    By moskakj in forum Samsung Galaxy Ace
    Last Post: 12-12-2012, 01:09 AM
  2. 1080p Video Doesn't Play on Galaxy Note???
    By Theguy in forum Samsung Galaxy Note
    Last Post: 04-21-2012, 02:04 AM
  3. Samsung Galaxy Note to start rolling out on November 2?
    By danDroid in forum Samsung Galaxy Note
    Last Post: 11-11-2011, 05:11 PM
  4. Stuck at ATT logo (Recovery issue)
    By Verysafety in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 04-06-2011, 07:39 PM
  5. will not boot past the samsung logo
    By arbrooks in forum Samsung Intercept
    Last Post: 02-28-2011, 03:14 PM
galaxy note 2 stuck on opening screen
galaxy note 2 stuck on samsung screen
how can i fix my galaxy note ii from freezing on boot
how to fix samsung note 2 stuck on logo
my galaxy note 2 is stuck on samsung logo
note 2 pit file download
note 2 stuck on boot screen
note 2 stuck on samsung logo
note 2 wont boot past samsung logo
pit file to repair note 2 stuck on samsung screen
samsung note 2 hang on logo
samsung note 2 stuck on samsung logo
samsung note 2 wont open
samusung note 2 cannot boot up
