Pantech Flex Advice, Cannot Root Again
This is a discussion on Pantech Flex Advice, Cannot Root Again within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi all, Hoping for a little help getting things back to where I would prefer them. Pantech Flex P8010 ICS 4.04, currently mostly stock, with ...
Thread: Pantech Flex Advice, Cannot Root Again
    Android Lurker kaland999's Avatar
    Oct 2013
    Hi all,
    Pantech Flex P8010
    ICS 4.04, currently mostly stock, with a few errors in the factory reset as far as I can tell. Previously rooted.
    The phone works fine currently (just not as well as I'd like), and will load the system recovery <3e> with reboot, apply update from external, wipe/factory reset, wipe cache, and apply update from cache options. The initial reason for rooting was to try and install CWM and some other small tweaks, and attempt to manually upgrade to JB. At some point I decided to attempt to unroot, factory reset, and see if I could force an OTA update. For whatever reason, removing too much bloatware maybe, the factory reset is fully functional, but has a few issues with the stock apps. However, I haven't been able to root the phone again since the reset, using the same, and different methods. I was wondering if there is a way to either go back completely to a fresh stock ICS, or possibly even to JB with the phone in an unrooted state. I've looked around a lot, and I haven't seen an answer involving my model of phone, so I figured I'd ask for advice to see if there was a general android solution before I tried too many things on my own and possibly bricked the phone.
    I'm actually giving up for the moment and heading to sleep, so no rush, but I'll check back as soon as I can.
    Thanks for any help!
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site.
    Oct 2013
    Update, through a combination of linux root methods, deleting all root app files on the external sd, and moving a few files for the Bin4ry root when running windows, I finally got it rerooted. I wish I had a better explanation of how, but I'm just glad it finally took.
    518 times
    Glad you got things worked out! I just went through a somewhat similar situation, rooting my Galaxy S3. Some of our forum staff are highly knowledgeable and qualify as technicians. I am NOT part of that group. My efforts to root were stressful, due to my own efforts - it usually works better if you follow the instructions. Fortunately the Galaxy S3 is difficult to actually brick, and returning to the starting point and doing it correctly the second time resulted in a successful root and installation of a custom rom. My point being: I had to stumble through the installations but it all worked out well in the end.
    Android Lurker zahidzzz's Avatar
    Sep 2014
    Will u please tell me the whole procedure . I m on the same situation on pantech flex p8010 ics
  1. Replies: 0
    Last Post: 10-23-2013, 11:59 AM
  2. Welcome to the LG G Flex Forums!
    By cereal killer in forum LG G Flex
    Last Post: 10-18-2013, 08:17 PM
  3. Pantech Breakout Root Help
    By estonb in forum Rescue Squad General
    Last Post: 07-08-2012, 08:45 AM
  4. Replies: 0
    Last Post: 01-24-2012, 04:42 PM
  5. Decided to root, advice please!
    By gregornz in forum Nexus One
    Last Post: 03-03-2010, 08:22 AM
bin4ry root v8
easy install cwm on pantech p8010
how access pantech flex stock recovery
how to completely wipe out pantech flex
how to get restoration point on a pantech p8010
how to install stock rom on p8010 without root acces
i rooted my pantech p8010, now what?
ics cwm pantech flex
is that possible to reroot p8010 ics
pantech flex jb system apps
pantech flex stock rom ics
pantech p8010 root problem
rooting a pantech flex results
wipe cache partition pantech flex
