Motorola Admiral Won't Finish Booting, Loops After FC
This is a discussion on Motorola Admiral Won't Finish Booting, Loops After FC within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; What phone? Motorola Admiral XT603 What ROM? Software Version: 5.5.1Q-117_PAX-79 / Flex Version: XSAXT603SPR01NA017.0R / Bootloader Version: 0016 Rooted or Stock? Rooted Overclocked? No What ...
Thread: Motorola Admiral Won't Finish Booting, Loops After FC
    Android Lurker yapper's Avatar
    Dec 2013
    • What phone? Motorola Admiral XT603
    • What ROM? Software Version: 5.5.1Q-117_PAX-79 / Flex Version: XSAXT603SPR01NA017.0R / Bootloader Version: 0016
    • Rooted or Stock? Rooted
    • Overclocked? No
    • What EXACTLY did you do to get to the state you are in? I wish I remembered exactly, but basically I was 'cleaning up' by removing unwanted apps with CleanMaster and I obviously deleted something important ...
    It starts to boot and then complains that "The application SprintOmaDm (processcom.motorola.android.sprintomadm) has stopped unexpectedly". It then attempts to connect to the network and the same forceclose message appears ... again and again. I can switch USB connection modes (charge only / USB mass storage / Windows Media Sync / Motorola Phone Portal), and select and connect to my wifi network but I can't get to the Android launcher screen.
    ADB won't connect (I suspect USB debugging is turned Off but I can't access Settings to turn it on). I can go into fastboot mode and I can see the device from my PC using fastboot devices so I'm hoping there is some way I can restore a factory image and get my phone working once more!
    From the research I've done, deleting /system/app/SprintOMADMConnMOPlugin.apk and .odex might resolve the problem, but I can't use ADB to do the deleting. I've tried creating an update.zip that includes the following updater-script, but it doesn't seem to help (I'm a total noob )
    Code:
    ui_print("");
    ui_print("started. . . .");
    run_program("/sbin/busybox", "mount", "/system");
    delete("/system/app/SprintOMADMConnMOPlugin.apk");
    delete("/system/app/SprintOMADMConnMOPlugin.odex");
    ui_print("Removed Sprint stuff ...");
    show_progress(1.0,0);
    unmount("/system");
    set_progress(1.00);
    ui_print("Done !");
    Is there some other way to do the deleting? I don't use the device as a phone, just as a tablet via wifi. It worked fine before I screwed it up ! Help!
    518 times
    Welcome to the forum - sorry that you're experiencing problems with your phone. I'm not a technician but if you can be patient for awhile, we'll try to get someone over here to give you a hand.
  1. Replies: 0
    Last Post: 11-09-2012, 09:47 AM
  2. auto re-booting
    By bukzin in forum Nexus One
    Last Post: 04-07-2012, 12:42 PM
  3. nexus one not booting up
    By jayguru11 in forum Nexus One Tech Issues / Bug Reports
    Last Post: 01-24-2012, 04:35 PM
  4. Motorola Admiral Leaked Destined For Sprint
    By WenWM in forum Android News
    Last Post: 10-09-2011, 08:09 PM
  5. HTC Wildfire not booting
    By spulkit in forum Android Forum
    Last Post: 09-03-2011, 08:51 AM
bootloader motorola xt 603
com.motorola. android.sprintomadm
fastboot mode motorola xt603
moto. admiral won't boot
motorola admiral rom
motorola xt603 bootloop
motorola xt603 fastboot mode
motorola xt603 force close
motorolla xt603 bootloader
my motorola xt603 wont boot up
rom motorola xt603
sprintomadm
sprintomadmconnmoplugin.apk
xt603 rom
xt603 rom download
