Galaxy S2 Help
This is a discussion on Galaxy S2 Help within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hey guys I wonder if anyone can help me ountreset my phone. I took it the sprint store with no luck. I just need to ...
Like Tree2Likes
  • 1 Post By CR6
  • 1 Post By grenefroggie
Thread: Galaxy S2 Help
    Android Lurker Warpcore47566's Avatar
    Apr 2014
    Galaxy S2 Help
    Hey guys I wonder if anyone can help me ountreset my phone. I took it the sprint store with no luck. I just need to last out a little longer til the S5 comes out. I cant get past the black Samsung screen and to do I system reset I get the option at the top of the screen and underneath I get this:
    E:failed to mount/system (Invalid Argument)
    cant mount system (Invalid Argument
    E:failed to mount /data (Invalid Argument)
    cant mount /data (Invalid Argument)
    E: failed to mount /data (Invalid Argument)
    E: failed to mount /system(Invalid Argument)
    E: failed to mount /cache(Invalid Argument)
    E: Cant mount /cache/recovery/log
    E: Cant open /cache/recovery/log
    E:failed to mount /cache(Invalid Argument
    E: Cant mount /cache/recovery/last_log
    E: Cant open /cache/recovery/last_log
    E: Failed to mount /cache(Invalid Argument)
    E: Cant mount /cache/recovery/last_install
    E: Cant open /cache/recovery/last_install
    E: failed to mount /efs(Invalid Argument)
    E: Cant mount /efs/log/boot_cause
    E: Cant open /efs/log/boot_cause
    That is what reading on the screen. If anyone cant tell me what it means and what I can do to fix it will be greatly appreciated. Like I said I just need to get it working for little while longer.
    Super Moderator CR6's Avatar
    Idaho
    223 times
    Did you attempt to root your device? Can you get into recovery? (hold down the volume up, Home and power button at the same time) you should be able to do a factory reset from there. If that doesn't work, you may need to flash the stock firmware via Odin. Let us know where you stand first and what you attempted before these error messages came up.
    tap'n
    Apr 2014
    I can get into recovery but when I try to do it nothing happens. I don't know what root is. How do I flash the stock firmware with Odin?
    Rescue Squad grenefroggie's Avatar
    Apr 2012
    50 times
    You have to be able to get in to download mode to flash back to stock. Almost same process as loading in to recovery, except use the volume down button.
    UltraDroid likes this.
    Android Lurker sunshineNote2's Avatar
    Jul 2014
    Download mode is frozen on Downloading too. Any other way to fix this issue?
  1. Replies: 1
    Last Post: 10-11-2013, 03:33 PM
  2. Replies: 0
    Last Post: 10-10-2013, 11:14 AM
  3. Replies: 1
    Last Post: 08-20-2013, 01:56 AM
  4. Replies: 10
    Last Post: 03-19-2013, 10:15 AM
  5. Replies: 1
    Last Post: 01-18-2013, 10:00 AM
android failed to mount /cache android system recovery
cant mount cache recovery commend
e failed mount cache note 2
e failed to mount data invalid argument galaxy s3#q
e failed to mount system invalid argument note 2
failed to mount /cache (invalid argument)
failed to mount /efs (invalid argument) s2
failed to mount /system (invalid argument)
galaxy note 10.1 e:failed to mount/system (invalid argument)
mount /system on samsung galaxy s2
samsung galaxy note 10.1 gt-n8013 e:failed to mount /system (invalid argument)
samsung galaxy note 2 e failed to mount/system
samsung galaxy s2 fadelid to mount/system
samsung s2 e failed to mount /efs
us.cellular reset of galaxy s2
