ODIN Screen Help
This is a discussion on ODIN Screen Help within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I got the odin screen up finally but all I get is the screen saying Downloading... Do not turn of target. I have taken out ...
Thread: ODIN Screen Help
    Android Lurker Warpcore47566's Avatar
    Apr 2014
    ODIN Screen Help
    I got the odin screen up finally but all I get is the screen saying Downloading... Do not turn of target. I have taken out the battery and I have wiped the cache from the recovery screen. I am trying to use odin to reset my phone because I cant do it from the recovery screen with the errors it has. Any help is appreciated.
    Rescue Squad grenefroggie's Avatar
    Apr 2012
    50 times
    Do you have a .tar file to flash to the phone?
    Does Odin see the phone? There will be a number under the ID:COM box.
    Is it loaded in the PDA box? Is the box next to PDA checked? Is Auto Reboot and F. Reset Time checked?
    Nothing else should be checked. If it is, might have some trouble.
    Give that a lookover and see what you come up with.
  1. Replies: 1
    Last Post: 02-21-2013, 01:15 PM
  2. Replies: 0
    Last Post: 10-22-2012, 11:22 AM
  3. Replies: 0
    Last Post: 10-08-2012, 05:12 PM
  4. X18i - SP Flash Tool or Odin
    By kingvasu in forum Rescue Squad General
    Last Post: 06-22-2012, 04:05 AM
  5. [ODIN] Leak USCC Froyo EA11 Stock + Root
    By dcow in forum Samsung Mesmerize
    Last Post: 02-07-2011, 10:00 AM
