Removed Microphone Bar by Accident
This is a discussion on Removed Microphone Bar by Accident within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi Everyone, I held it down too long and swiped to remove. I'm not taking about the microphone on the keyboard which is what a ...
Like Tree2Likes
  • 1 Post By CR6
  • 1 Post By alank2
Thread: Removed Microphone Bar by Accident
    Android Lurker alank2's Avatar
    Feb 2015
    Hi Everyone,
    I held it down too long and swiped to remove. I'm not taking about the microphone on the keyboard which is what a search brought up how to fix, but I am thinking it is called a widget and it is on the home screen or desktop. It is as wide as the screen and had a place to type in something to search or you could click the microphone next to it and ask it something. I've tried going to apps and adding what looks like might be it back, but they show up on the home screen as an icon and not the search with microphone. I didn't see anything under widgets that looks right... Any ideas?
    Thanks,
    Alan
    Super Moderator CR6's Avatar
    Idaho
    224 times
    Scroll through your widgets, it will look something like this.
    Then simply long press on it to drag it to whatever homescreen you want it on.
    Good luck.
    S5 tap'n
    Feb 2015
    Thanks - mine looked different, but I did find one that had a google G icon and said 4x1 on it so I tried that and that was it! I appreciate the help!
    CR6 likes this.
  1. n1 removed app market
    By dgtlsl8v in forum Nexus One Tech Issues / Bug Reports
    Last Post: 12-15-2010, 10:34 PM
  2. how to find things removed
    By aronoffdvm in forum HTC EVO 4G Tech Support
    Last Post: 07-20-2010, 09:48 AM
  3. Does engraving get removed by...
    By Forge in forum Nexus One
    Last Post: 03-18-2010, 02:39 PM
