Nexus 4 - Android 5.1.1 Crashes
This is a discussion on Nexus 4 - Android 5.1.1 Crashes within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi Community, I despair! I have following problems: You know on the bottom of the phone you have three buttons: ◄ O ▓ If you ...
Thread: Nexus 4 - Android 5.1.1 Crashes
    Android Lurker csskevin's Avatar
    Jul 2015
    Hi Community,
    I despair!
    ◄ O ▓
    If you are on the unlock screen pattern u only have this one:
    - The problem is now, if I unlock my phone correct sometimes it freezes there. I can press that button and if I unlock my phone again, it freezes. I can send it to standby and wake it up again and unlock it but
    when I want to do smth it doesnt work
    - Then when I am going to make a call, often the phone manager crashes
    - When I am going to make a photo it crashes and shows me a black screen
    - When I am going to make a video and I press the Start button it freezes
    - Sometimes it crashes and restart automatically (When the smartphone is on the table in front of me) by 80% accu
    Even the problems appears when I went from Android 4 to Android 5 ... In Android 5 some of the called problem happend. The next update to 5.1 bring more problems. In 5.1.1 was firstly better. But a few days ago these above called problems happend.
    Please help me,
    Thanks in advance,
    csskevin
    PS: My phone never fell on the bottom. The last time is some months ago, and there havent been any bad result, excepting these problems, my phone already had.
    And my Nexus is not rooted!
    Sorry for my bad english
    // EDIT:
    What about downgrade to Android 4 (KitKat)?
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Welcome to the forum! Sorry to hear about your issues. Unfortunately there's no way to revert back to a previous OS version. That said, you can fix your issues with a factory data reset. It's always advised to perform a factory reset after a major update like this. Just make sure to back up your contacts, music, photos etc.
    Good luck and let us know how you make out.
    S5 tap'n
    Jul 2015
    Ok, I am going to try it.
    I will let you know if some problems appears
  1. com.android.settings Crashes While Trying to Use as Hands-Free
    By _artem_ in forum Unlisted Android Phones
    Last Post: 09-13-2012, 01:32 AM
  2. Replies: 0
    Last Post: 02-03-2012, 03:30 PM
  3. Replies: 2
    Last Post: 05-05-2011, 01:35 PM
  4. nexus one crashes when making/receiving calls via bluetooth
    By NMK in forum Nexus One Tech Issues / Bug Reports
    Last Post: 02-17-2011, 03:27 PM
  5. Adsense crashes android
    By fabkebab in forum Nexus One Tech Issues / Bug Reports
    Last Post: 02-09-2010, 11:04 PM
android 5.1.1 phone crashes
android settings problems on android 5.1.1
