Rooting Troubles
This is a discussion on Rooting Troubles within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; So I have a galaxy s4 (sgh-m919) and I bought it rooted. (both binary and ROM are custom when put into odin). However, SuperSU and ...
Like Tree1Likes
  • 1 Post By CR6
Thread: Rooting Troubles
    Android Lurker Theofficialdmg's Avatar
    Jan 2016
    Rooting Troubles
    So I have a galaxy s4 (sgh-m919) and I bought it rooted. (both binary and ROM are custom when put into odin). However, SuperSU and other super user apps say that the device is unrooted, does this mean that the root failed? Whatever the case, how can I do an unroot?
    I'm not the biggest fan of 4.2.2, and I'm tired of 3rd party launchers, lockers, and status bars. I really just want the 4.4 OTA
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Without knowing what method was used to root, it's difficult to tell you how to proceed. You might Google "S4 SGHM919 return to stock" and see what directions pop up. You could also try downloading KIES to your PC, and try pushing an OTA update that way. Usually that will break root and return you to stock while updating your device.
    (Just make sure to backup all your contacts and files before doing anything)
    Good luck!
    S5 tap'n
  1. Bluetooth Troubles
    By Lifeguard in forum Android Forum
    Last Post: 01-07-2015, 01:11 PM
  2. Troubles with Touchscreen
    By Ramek in forum HTC EVO 3D Tech Support
    Last Post: 03-30-2012, 10:26 AM
  3. Troubles
    By eldamian3 in forum Sony Xperia Play
    Last Post: 08-15-2011, 12:44 PM
  4. Help with Rooting troubles
    By rhines13 in forum Nexus One Development & Hacking
    Last Post: 04-06-2010, 07:58 PM
