How to fix random reboots on droid incredible
This is a discussion on How to fix random reboots on droid incredible within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; So i know you asked us to put the rom and everything in our posts but from what i have read the droid incredible reboots ...
1Likes
Super Moderator
So i know you asked us to put the rom and everything in our posts but from what i have read the droid incredible reboots randomly on all roms made for it. So what i am looking for is a fix all for the random reboot issues. I posted a thread about one fix i found but it doesnt work on all droid incredibles so i thought i would ask for a little help
Android.net is the premier
Super Moderator/RS
Which fix is this (sorry, I'm not a big Inc follower because I have a D1)? And is it SLCD-only or does it seem to be random and cover all hardware revisions?
Android Sr Member
probbie, not all ROMs cause random reboots. If you're experiencing this then there's either a problem with how you flashed the ROM (forgot to wipe, perhaps), the ROM itself, or your phone. Sometimes, reflashing the same ROM can solve any weird issues you're having. What ROM are you running?
Themer
Cm6.1 never gives me reboots.
Sent from my ADR6300 using Android.net App
There is not much to look at in this signature.
Super Moderator
I apologize i thought i linked this Random Reboots but i currently am running cm6.1 with this hulu hack How to watch Hulu on your rooted Android 2.2 device and 20 minutes into a show it would reboot and then keep rebooting so how i fixed it like the first link says is i just used set cpu to set the cpu lower and now it works, so i bought one of ebay that had random reboots thinking i could fix it, i had to put it in the fridge to get it cool enough to even use it so i rooted it quick and installed clockwork mod recovery all in about 20 minutes and then it started rebooting again so i put it back in the fridge then i did a nandroid back up of my rom on my phone that i know works and flashed it to that phone and no go still would reboot. So i tried skyraider on it no go i tried uncommon sense still no go. So i was hoping you guys had a one size fix all kind of fix, if you read my first link that will give more information. I was more looking for ideas on how to fix this issue but i am happy for you guys that you havent had to deal with it on your devices because if you just google this issue you will see how common it is
Super Moderator
So I was just using GPS and my phone rebooted. Any fixes ?
Android Sr Member
Try something like Redemption ROM- very stable. If it reboots on that (after a full data/cache/Dalvik cache wipe) then it's most likely a problem with the phone itself.
Super Moderator
I will try and I think it is a problem with the design of the incredible but its al hit or miss with people but I will try that thank you
Android Sr Member
Android Enthusiast
Originally Posted by
enlightened
Battery temp reading safety reboot maybe ?
Pencil eraser on the terminals clean?
It stopped my old LG6100 from false heat reboots (pretty much my first action with every model phone problem since) back about when batteries first started getting the ability to tell the phone to shut off. if too hot. Before that only moto batteries had the chip .
Support Our Troops!!
This post was Tapatalk approved.
The United States is the land of the free because of the brave!
Thank You to all who serve, have served in the U.S. military ,and to their families for your sacrifices. They are not in vain.
May God bless the United States of America
- You may not post replies
- You may not edit your posts
Forum Rules
By enlightened in forum Android Rooting
Last Post: 02-24-2012, 01:50 PM
By danDroid in forum HTC Droid Incredible
Last Post: 01-16-2011, 11:31 PM
Last Post: 10-05-2010, 04:25 PM
droid incredible auto reboot
droid incredible keeps rebooting fix
how to reboot my droid incredible
how to solve my htc incredible s from rebooting
htc droid incredible reboot loop fix
htc droid incredible reboots itself
htc incredible 2 restarts itself
htc incredible automatically reboots
htc incredible keeps rebooting
htc incredible random reboot
htc incredible reboot problem
htc incredible restarts randomly
htc sense taiwan how to fix random restarting
my htc incredible keeps rebooting
solution to htc incredible that keeps rebooting
