Importing Contacts?
This is a discussion on Importing Contacts? within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I know there are apps you can use to do it, but last I was aware the cheapest one was like $20. Another option would ...
Super Moderator/RS
I know there are apps you can use to do it, but last I was aware the cheapest one was like $20. Another option would be to see if you could get GMail to import your contacts from Outlook and use it only as an intermediary in the process.
DO NOT WRITE IN THIS SPACE
- You may not post replies
- You may not edit your posts
Forum Rules
By vierannie in forum LG Optimus V
Last Post: 04-26-2011, 08:47 PM
By airbusio in forum Android Forum
Last Post: 03-03-2011, 08:48 PM
Last Post: 12-05-2010, 10:27 AM
Last Post: 09-04-2010, 07:09 PM
g2x transfer contacts to htc one
gmail didnt import all contacts to htc one
how to add contacts to gmail on android tablet
how to import contacts from sd card htc one v
how to import info on optimus v
how to inport numbers from lg optimus v
how to transfer contacts from lg g2x with google to htc one phone
import contacts from sd card to htc touch 2 pro
import gmail contacts htc one v
import gmail contacts to android tablet
import vcard htc touch pro 2
lg g2x import contacts
no vcard file found on sd card
rescue contacts android
sending v card contact via sms message lg g2x
