droid x bootstrap problem
This is a discussion on droid x bootstrap problem within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Ok rescue squad.I'm having troubles with getting bootstrap on my phone..first of all I'm having truoble downloading certain,apps and bootstrap is one of them I ...
Thread: droid x bootstrap problem
    Android Lurker 861289's Avatar
    Ok rescue squad.I'm having troubles with getting bootstrap on my phone..first of all I'm having truoble downloading certain,apps and bootstrap is one of them I vmcant download it from the market but that's a whole other issue I need help with..but I can download bootstrap from koush free site download..that being said once it downloads and the download is complete in my status bar I click on it and it gives me the option to (complete action using rom manager when I click on rom manager it takes me to rom pre installation and gives me the option to back up existing rom wipe data and cache wipe dalvic cache and wipe dalvoc cache already has a check in the box..if I select ok it takes me to reboot and install and tells me to press ok to reboot into clockwork mod recovery and continue the installation...now my problem is no where on my phone is the bootstrap recovery app installed so what's up what do I need to do..I'm rooted have clockwork mod recovery and have liberty toolbox installed.I have rom manager and titanium backup please help..what do I do...
    197 times
    FurryVarmint
    Settings> Applications> Allow Unknown Sources
    Now install Astro File Manager from the Market, open it, navigate to the download (not downloads) folder on the SD card, and locate the bootstrapper .apk file. Press it and it should give you the option to install via the app manager. Let us know if you're still having problems!
    DO NOT WRITE IN THIS SPACE
    El Paso, TX
    59 times
    _B0BB0_
    Yup you should have an option to use packet installer, use that to install the apk. I haven't seen the free apk on his site in awhile so ensure its droidx bootstrapper apk before installing.
  1. [DX HOW TO] Use Droid X Bootstrap
    By Droid-Xer in forum Android Rooting
    Last Post: 03-22-2012, 06:32 PM
  2. adw launcher problem
    By tom101 in forum Android Forum
    Last Post: 07-06-2011, 01:45 AM
  3. G2X-Do I have a problem
    By Drew Clifford in forum Rescue Squad Help
    Last Post: 05-16-2011, 07:20 PM
  4. The problem with flashing Motorola Droid 2 Global Verizon
    By webby_toor in forum Motorola Droid 2 Global
    Last Post: 05-01-2011, 02:19 AM
  5. Wi-fi problem
    By Jef-Droid in forum Motorola Droid X
    Last Post: 02-14-2011, 10:42 PM
bootstrap not working droid x
droid 2 bootstrap download free
droid 2 bootstrap not working
droid 2 bootstrap on droid x
droid 2 bootstrapper not working
droid 2 bootstrapper.apk
droid x bootstrap
droid x bootstrap not working
droid x bootstrapper not working
droid2 bootstrap download free
free bootstrap recovery droid 2global apk
issues with bootstrap droid x
koush's bootstrap free download for droid 2 global
uninstall droidx bootstrap before installing droid2 bootstrap?
