Xperia X8 - Useless icons problem
This is a discussion on Xperia X8 - Useless icons problem within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hello! I got my Xperia today, and i must say it's really nice. But i'm having one problem with it - I bought it from ...
Thread: Xperia X8 - Useless icons problem
    Android Lurker Gilad's Avatar
    Hello!
    I got my Xperia today, and i must say it's really nice. But i'm having one problem with it - I bought it from a company called Pelephone (the one who got first place in the speedtest.net thingy), and they put LOADS of apps, which shouldn't be there in the original thing. I counted it, they put 19 apps (if i'm not wrong.). I really want to uninstall / remove them from the phone, because it takes 2 pages, and it just makes one whole mess.
    Take note i'm new to Android and i have no idea about anything. Plus i'm having mac, and I don't have windows. (if there is no mac guide at all, then you can give windows guide. I can do it on a friend's house or something)
    Thanks alot!
    EDIT:
    Btw i got 2.1 version.
    Also, if it's possible to put all of them in one folder / make the icons hidden that will be fine too.
    El Paso, TX
    59 times
    _B0BB0_
    If they don't appear by going to settings/applications/manage applications then they are system apps and not removable unless you root. Or download an uninstaller from the market and try that.
  1. G2X-Do I have a problem
    By Drew Clifford in forum Rescue Squad Help
    Last Post: 05-16-2011, 06:20 PM
  2. Replies: 0
    Last Post: 02-13-2011, 05:14 PM
apps icon for xperia x8
deleting icons x8
how to delete icons on xperia x8
how to hide icon xperia x8
how to hide icons on xperia x8
how to make xperia x8 icons
remove icon after uninstall xperia
remove unwanted icons from xperia x8
sony xperia how to delete icon
xperia hides icons
xperia m what useless apps to delete?
xperia x8 hide apps
xperia x8 hide icons
xperia x8 icons
z4root download
