Dell Streak Help
This is a discussion on Dell Streak Help within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I am using dell streak 5 Updated to Android 2.2. I havent done anything else in it. I use advanced task killer v1.9.6 build 76 ...
Results 1 to 10 of 11
Thread: Dell Streak Help
    Android Lurker kukudbz's Avatar
    Jun 2011
    India
    Dell Streak Help
    I use advanced task killer v1.9.6 build 76 by rechild.
    Now whenever I kill the selected applications and exit from the ATK after a few seconds when I start it again I again see all of the applications are running. And no I dont start them its by default. This drains my battery like anything. Can you please help me. Is the task killer not good or is something that I am doing wrong.
    Please help. Thank you
    197 times
    FurryVarmint
    There are no good task killers. Stop using it. ATK is draining your battery as well.
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    I concur with Fbm. Quit using task killer. The Only reason to task kill an app is if that app is causing a problem and it won't let you uninstall it or force close it.
    Jun 2011
    India
    okay... but what should I do about all those applications which continuously run in the background?
    Somewhere on Kamino
    83 times
    What apps are running in the background that you want to stop?
    197 times
    FurryVarmint
    The OS will cache and even kill them, unless they're protected, to free up more RAM for new applications.
    The Android OS is designed to run with all the RAM full, unlike a desktop OS. Don't think of it as a PC, think of it as a mobile computing device.
    El Paso, TX
    59 times
    _B0BB0_
    Ya just let the OS handle it. Running processes sit idle unless you're using them. So no worries.
    Jun 2011
    India
    ummm... okay... i am not satisfied but still if you all say so... One last query though why do they run on their own even when I quit them.
    Almost all the applications like Market, application locker, settings, email, and horde of all things are simply running even if i don't open them and also when I open and exit out...
    Sorry for being like this ( I forgot the word what it's called!) the thing is this is my first ever Android phone and the experience is too overwhelming after a decade of using Windows Mobile and Symbian 60.
    Somewhere on Kamino
    83 times
    The ones you listed need to run for your device to work properly.
    197 times
    FurryVarmint
    That explains why you're used to having to kill tasks. Android handles it for you. I've been using my phone heavily without a reboot and without having to kill a single task for 48+ hours at this point without any lag, slowdown, or other issue. Of course, I'm not using a task killer, antivirus, or other totally-unneeded thing. And if it starts to lag or whatever I just reboot. Two minutes and my phone is fresh, snappy and fully-functional. It's not like rebooting a Blackberry, PC, or any other device.
  1. T-Mobile Now Selling the Dell Streak 7 Tablet
    By wicked in forum Android News
    Last Post: 04-03-2011, 11:10 PM
  2. DELL Streak 001DL
    By KansaiRobot in forum Dell Venue
    Last Post: 03-28-2011, 06:45 AM
  3. Android 3.0 Honeycomb Ported to Dell Streak
    Last Post: 02-11-2011, 07:25 PM
  4. Replies: 0
    Last Post: 01-31-2011, 10:28 AM
  5. T-Mobile announces Dell Streak 7, it's first 4G Tablet
    By JohnDroid in forum Android News
    Last Post: 01-06-2011, 03:22 PM
close apps dell streak 7
dell streak 7 close applications
dell streak 7 close apps
how do you close apps on dell streak 7
how long to charge dell streak 7
how to close applications on dell streak 7
how to close apps in dell streak
how to close apps on dell streak
how to close apps on dell streak 7
how to close open apps on dell streak 7
how to close running apps in dell streak 7
how to close running apps on dell streak 5
how to close windows in dell streak
how to close windows on dell streak 7
my dell streak 7 wont open applications
