Droid
This is a discussion on Droid within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Ok I need help with this Droid I got its rooted and they didn't know what they was doing I'm trying to factory restore it ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Droid
    Android Jr Member Liquidvortex's Avatar
    Jun 2011
    henderson,ky
    Droid
    Ok I need help with this Droid I got its rooted and they didn't know what they was doing I'm trying to factory restore it but the file is gone can I get it back I just want it normal
    Sent from my Droid using Android.net
    El Paso, TX
    59 times
    _B0BB0_
    You will need to sbf your phone if you want it 100% stock. What's the reason for unrooting?
    Somewhere on Kamino
    83 times
    I agree with xer and I would like to know why as well?
    Jun 2011
    henderson,ky
    I bought the phone from Craigslist its just not running right I love just love this phone but who ever did it did itvthe wrong way alot of stock apps are missing it's not updating the market and android system
    Somewhere on Kamino
    83 times
    So then flash the rom that you have on your other vortex to the one that doesn't have stock apps.
    197 times
    FurryVarmint
    You'll want to flash a file called SBF onto the phone to get it back to stock, then reroot since flashing a ROM might not take and you'll have to SBF anyway. If you're unfamiliar with the process we will provide links to both information and the files you'll need. I'd suggest flashing FRG22D on if you can. The reason being that gives you the most options to root, and once you're rooted you'll have a few options to flash recovery. As for recovery, I'd suggest you stay away from ROM Manager and ClockworkMod Recovery as both are problematic.
    So, when you're ready to begin, just let us know and we'll get you started!
    DO NOT WRITE IN THIS SPACE
    Jun 2011
    henderson,ky
    I'm so ready
    197 times
    FurryVarmint
    Alright. What OS do you have on your computer? If you have a Mac we'll need to figure something out because doing this on a Mac can be tricky. If you have Windows you'll need the Moto Connect drivers from Motorola, RSD Lite 4.6, 4.8, 4.9, or 5.0. Do not get 4.7; even patched you might have problems. If you have Linux you'll need SBF_Flash. When you tell me what you have I'll link you to the proper download.
    Next up would be the SBF file. You'll need this regardless of the OS, so since I'd said you'll want FRG22D you'll want this one. http://wonderly.com/bb/DROID/OEM/VZW..._SW_UPDATE.sbf
    Jun 2011
    henderson,ky
    I have windows 7
    197 times
    FurryVarmint
    http://wonderly.com/bb/DROID/OEM/rsdlite_5.0.msi That's RSD Lite 5.0. Let me know when you have that installed. I'll link you to very detailed step-by-step instructions on how to flash the SBF I linked you to earlier onto the Droid 1, but the process is similar (if not identical) for all Motorola phones.
  1. Replies: 18
    Last Post: 05-02-2011, 09:35 AM
  2. wtt droid incredible for samsung fascinate or droid x
    By mbaverizon in forum Android Hardware for Sale
    Last Post: 04-08-2011, 12:35 AM
  3. Replies: 0
    Last Post: 03-15-2011, 10:44 AM
  4. Replies: 28
    Last Post: 03-14-2011, 07:29 AM
android vortex oem download
download frg22d.sbf
download frg22d.sbf file
flashing lg vortex to stock
frg22d sbf download
frg22d.sbf
frg22d.sbf download
frg22d.sbf file download
frg22d.sbf file verizon
frg22d.sbf free download
lg vortex oem rom
lg vortex rom manager
lg vortex sbf
lg vortex sbf download
rooted lg vortex back to oem
