Help! 2 Issues
This is a discussion on Help! 2 Issues within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I posted this somewhere else but noone replied so maybe I posted in the wrong section. My keyboard on my G2 doesnt light up anymore ...
Thread: Help! 2 Issues
    Android Jr Member dvdman's Avatar
    Help! 2 Issues
    I posted this somewhere else but noone replied so maybe I posted in the wrong section. My keyboard on my G2 doesnt light up anymore when I open it up to use it. Helpful in dark places. Also, when I make a call the screen goes blank. The phone makes calls as normal but I can't hang up the phone by hitting the end button cuz I cant see it. If I open the keyboard while making the call everything is fine. I can see the end button and dial pad but this can somewhat annoying.I couldnt find a thread and I cant seem to get any replies. Thanks for any advice...
    Administrator wicked's Avatar
    San Jose CA.
    259 times
    wwickedd
    Have you tried a battery pull? Take out battery for 30 seconds and restart phone. See if that helps.
    Android Enthusiast Martin030908's Avatar
    6 times
    is your hand/finger blocking the proximity sensor by any chance? That might explain why the screen stays dark... or maybe it's an issue with the proximity sensor.
    Somewhere on Kamino
    83 times
    Do you have a case for your device? If so is it blocking the sensor? Have you pulled the battery like Wicked suggested? Smartphones need battery pulled at least once a week to kind of reset themselves so to speak.
    Somewhere on Kamino
    83 times
    What tablet?
    Columbia, Misery (Missouri)
    8 times
    The battery pull solved the problem for me.
    sorry trying to discard this post but it won't go away. I just noticed the date on the post I was replying to.
  1. Device issues
    By nrkpai in forum Unlisted Android Phones
    Last Post: 06-21-2011, 06:44 PM
  2. Root Issues?
    By SynysterCarm in forum Android Forum
    Last Post: 06-13-2011, 05:29 PM
  3. Issues with z4root
    By jon_l85 in forum Android Rooting
    Last Post: 03-09-2011, 10:24 PM
  4. Gallery Issues
    Last Post: 12-20-2010, 01:00 AM
  5. Gps issues validated...
    Last Post: 08-18-2010, 10:54 PM
g2 keyboard backlight
g2 keyboard doesnt light up
g2 keyboard light
g2 keyboard light up
g2 keyboard lights
g2 keyboard wont light up
google g2 keyboard wont light up
how to make keyboard light up on g2
htc g2 keyboard backlight
htc g2 keyboard doesnt light up
htc g2 keyboard light
htc g2 keyboard wont light up
keyboard wont light up droid 2
keyboard wont light up on g2
my g2 keyboard wont light up
