ROM manager can't work on my phone
This is a discussion on ROM manager can't work on my phone within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I have installed Rom manager on my HTC Hero GSM. When I try to backup my current Rom, my phone reboots to a white screen ...
Results 1 to 8 of 8
Thread: ROM manager can't work on my phone
    Android Lurker Chrysolite's Avatar
    I have installed Rom manager on my HTC Hero GSM. When I try to backup my current Rom, my phone reboots to a white screen with the initials HTC and stays like that. The same thing happens when I command a "install Rom from SD" operation. Any one please help.
    Rescue Squad fish1552's Avatar
    Savannah area of Coastal Georgia
    7 times
    fish1552
    Can you reboot the phone and get back into Android, or are you stuck there? What version of Rom Manager and Busybox do you have? Also, which recovery version do you have? You should be able to see it near the bottom of the RM screen.
    Android Jr Member mamawm's Avatar
    mississippi
    14 times
    i don't know about the hero, but i have an eris and they are supposed to basically be the same phone and rom manager does NOT work on the eris.
    Somewhere on Kamino
    83 times
    Have you tried titanium back up?
    197 times
    FurryVarmint
    Did you flash recovery first?
    DO NOT WRITE IN THIS SPACE
    7 times
    fish1552
    +1 I'm beginning to think that kousch may need to put a huge flashing pop up in the app telling people "Hey! FLASH THE RECOVERY FIRST!!!!" Or maybe have a button that says "Prep phone for ROMs << Use this prior to doing anything else!" where it checks for all that stuff. Because I know when I first used it I did the same thing not knowing otherwise.
    Also Chrysolite, I don't see in any previous post where you downloaded and installed an actual ROM. So if you are trying to backup your current configuration in order to go back in case you have problem installing your first ROM, you need to do that from ClockworkMod Recovery, not ROM Manager.
    Follow these steps:
    1) use the top option in Rom Manager to "Flash ClockworkMod Recovery.
    2) use the second option in Rom Manager to Reboot into Recovery.
    3) once in recovery use the volume keys to scroll down to "backup", then from the second menu select backup again Wait while it does a full system backup. (If something in a ROM install later goes wrong, go back to here and simply choose "restore" to go back to this.
    3) Go back to ROM Manager and "Download ROM"
    4) Use Install ROM from SD Card (I'm assuming the Hero has one?)
    5) Once it runs everything (it should reboot and after some time you should see the screen say "complete" somewhere) you can go back into Rom Manager and THEN choose Backup Current ROM.
    Somewhere on Kamino
    83 times
    I agree fish. Maybe we should create that app. :D
    7 times
    fish1552
    I wish I knew enough to do it. I'm only in Chapter 1 of a book trying to learn it, so maybe in about 20 yrs when the next thing comes out, I'll be ready in time to be obsolete.
    All I wanna to is Xooma-Xoom-Xoom-Xoom > > > from my Xoom Xoom.
    When rooting your device, preparation makes all the difference.
  1. HTC Desire Z - Better Quality Battery
    By razzle in forum HTC Desire Z
    Last Post: 03-17-2011, 10:54 AM
can't find my phone model in rom manager
cant find my phone model in rom manager
cant find my phone model on rom manager
my phone is not listed in rom manager
my phone model is not listed in rom manager
rom manager backup not working
rom manager can't detect my phone
rom manager can't find my phone
rom manager for htc hero
rom manager hero
rom manager htc hero
rom manager not working htc hero
rom manager phone model not listed
rom manager white screen
rom manager work on htc hero
