Help!! Settings > Accounts and Sync disappeared
This is a discussion on Help!! Settings > Accounts and Sync disappeared within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; My problem is to find the correct apk that will work. I've tried various accountsandsyncsettings.apk that I found on the web, but none have succeeded. ...
Results 11 to 13 of 13
Thread: Help!! Settings > Accounts and Sync disappeared
    Android Lurker xxx567's Avatar
    I imagine I need the correct Android version and maybe a specific one for the Samsung Gio.
    Anyone with a Samsung Gio that can copy accountsandsyncsettings.apk and upload it?
    TIA.
    Rescue Squad das8nt's Avatar
    3 times
    I don't know if you have seen this thread yet. Unfortunately, they haven't posted the app dump from 2.2.1 yet, but the 2.3 is there. Not sure if that will be compatible or not. Maybe PM the author of the OP to see if he can pull them for you? Is your system deodexed or still stock odex files in place. You would need both the .apk and the .odex if your system isn't deodexed.
    xda-developers - View Single Post - [S5660] Galaxy Gio The big Thread! | Tips, Roots, fixes, Firmware, Custom Roms
    OK Thanks.
    I posted a request for the 2.2.1 apk and odex files.
    Hopefully I'll get a response.
    Thanks for your help.
  1. Videotron's APN Settings
    By iPeck in forum Other Carriers
    Last Post: 01-23-2013, 03:43 PM
  2. Replies: 1
    Last Post: 05-21-2011, 08:00 PM
  3. Galaxy S Brightness settings not good
    By Android_Galaxy_S in forum Android Forum
    Last Post: 02-08-2011, 04:21 PM
account and sync apk
account and sync settings 2.2.1 apk
account and sync settings android apk
account and sync settings android apk download
account and sync settings apk
account and sync settings.apk
account and sync settings.apk missing
accounts and sync apk
accounts and sync missing
accounts and sync settings missing
android accounts and sync missing
download account and sync settings android apk
google account and sync settings apk
google account sync apk
google accounts and sync apk
