Help!! Settings > Accounts and Sync disappeared
This is a discussion on Help!! Settings > Accounts and Sync disappeared within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; After rooting my Samsung Gio GT-S5660 (Android Version 2.2.1) , my Settings > Accounts and Settings disappeared. No idea what happened, it may be that ...
Results 1 to 10 of 13
Thread: Help!! Settings > Accounts and Sync disappeared
    Android Lurker xxx567's Avatar
    No idea what happened, it may be that I accidentally deleted it from the Settings.
    Not sure what to do. Do a full restore, or maybe something a little less painful...
    Please help. Thanks in advance.
    Mick
    197 times
    FurryVarmint
    Did you simply root it or flash a ROM?
    DO NOT WRITE IN THIS SPACE
    Simply rooted it.
    Not sure what happened, but now it's gone.
    Any suggestion how to proceed from here?
    197 times
    FurryVarmint
    What method did you use to root it? Because it sounds like there might be a problem with that method.
    As for fixing it, I'd consider unrooting or even flashing the stock ROM over your current root, but that might cost you all your data.
    Thank you for your reply.
    I simply used the update.zip file and rebooted in recover mode. The update.zip file I downloaded from
    How To Root The Samsung Galaxy Gio S5660
    But I think you're right, it was after the rooting that the Accounts and Sync disappeared.
    What method of unrooting do you suggest? In recover mode, there is a "Factory Reset", but I guess that would put me back to Square 1.
    If there is no other alternative, then I guess I can do that. I've only had the phone for a few weeks, so there isn't that much to be lost.
    197 times
    FurryVarmint
    If there's no direct-unrooting option you'll have to flash the stock ROM back on which will put you back to square 1. Best I can suggest is see if there's been an official update you can install via the update.zip method. If not you may be in a bit of a bind because a factory reset, generally-speaking, doesn't delete anything in the /system and that's where the root files are stored.
    Thanks for your reply.
    Would you or anyone else know if it would. be enough to get the correct version of accountsandsyncsettings.apk and copy it to system/app? I've seen some posts that suggested that. I tried it but it didn't work. Probably because I had an incorrect file version.
    Thanks.
    Sent from my GT-S5660 using Android.net
    197 times
    FurryVarmint
    I've never heard of that. It might. Fire up a terminal emulator and see if it's still there first, though.
    Thanks for your suggestion.
    Checked with emulator. Unfortunately, it's not anywhere in system/app.
    I'll keep looking for a solution ;-(
    197 times
    FurryVarmint
    If it got deleted then try pushing that .apk to the /system and see if it works.
  1. Videotron's APN Settings
    By iPeck in forum Other Carriers
    Last Post: 01-23-2013, 03:43 PM
  2. Replies: 1
    Last Post: 05-21-2011, 08:00 PM
  3. Galaxy S Brightness settings not good
    By Android_Galaxy_S in forum Android Forum
    Last Post: 02-08-2011, 04:21 PM
account and sync apk
account and sync settings 2.2.1 apk
account and sync settings android apk
account and sync settings android apk download
account and sync settings apk
account and sync settings.apk
account and sync settings.apk missing
accounts and sync apk
accounts and sync missing
accounts and sync settings missing
android accounts and sync missing
download account and sync settings android apk
google account and sync settings apk
google account sync apk
google accounts and sync apk
