Weather widget city/town location issues.
This is a discussion on Weather widget city/town location issues. within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hello all. Does anybody know how to/if it is possible to add a city or town to the weather widget that came pre-installed on my ...
Thread: Weather widget city/town location issues.
    Android Lurker DrJ's Avatar
    Hello all. Does anybody know how to/if it is possible to add a city or town to the weather widget that came pre-installed on my HTC Desire? It has a certain amount of cities and towns, and some surprising choices, smaller towns, but for all my poking about w/all the pref's and settings I cannot for the life of me see any option for setting/adding a new location that isn't preinstalled. Any help or ideas would be gratefully received. J.
    Rescue Squad fish1552's Avatar
    Savannah area of Coastal Georgia
    7 times
    fish1552
    You may need to change the settings at least temporarily from Use my location (GPS) to Set Location. Then add the location manually.
    1. Tap on the weather (figure 1)
    2. Tap the Menu icon
    3. Select Settings
    4. You now have a list showing Weather settings, News settings and Refresh settings
    5. Tap on Weather settings to instruct the device to: Use my location, Set location and/or use Celsius instead of Fahrenheit
    Thanks for yr advice. I think that either I'm missing something or doing something wrong, but I followed yr suggestions as closely as I could ( tapped on the weather widget(HTC Weather. V.3.0), next screen offered a +location and refresh option, pushed menu button, chose settings, and only settings available were for auto-updates, schedule update and temperature choice. Then tapped the word weather on the widget, and this took me to an online site, where it seem's that one's location can be changed to a place of choice, so alteredr) but nothing seems to alter or change as far as I can see. I have options on the widget to change the weather forecast for any city of my choice, (amongst those the widget allows, though not the one I need) but it makes no difference to the homescreen clock weather display, even when I reboot my device. I appreciate I may be repeating myself or making glaring errors and/or omissions, so I appreciate yr patience, but I've been fiddling w/my HTC Desire for hours now. Hope the above make sense. J.
    7 times
    fish1552
    Sort of. But I am going off of thing I've found online so they may be a bit outdated. I only have a Moto Droid & Xoom myself, so I may not have the same one you do since yours is HTC. And none of my co-workers have one right now either.
    If there is any information in that menu under maybe the "about" section that would give specific info as to blur version or widget version, maybe we can track something else down.
    You would think they would make it easier to do something that I think would be common.
    ---From my Xoom
    When rooting your device, preparation makes all the difference.
  1. New kid in town!!!
    By Sexytx in forum Introductions & Site Assistance
    Last Post: 03-11-2011, 10:23 AM
  2. New kid in town!!!
    By Sexytx in forum Off-Topic Forum
    Last Post: 03-11-2011, 12:23 AM
adding locations to note 3 weather widget
android location location refresh time
cannot change celcius to farenheight on tablet
change city for weather on samsung 3
change weather location on samsung galaxy s5
galaxy gear add city to weather widget
how do.youset weather on android
how to change the weather city on my samsung android prime core tracfone
how to change weather location on galaxy s5
how to i edit the city on the weather app on s4
i want to change default weather area on samsung galaxy tab 3
samsung galaxy 4 how to change city for weather info
samsung galaxy s5 weather widget set city
samsung s4 how to change location of weather
tab 3 how to add a city on the weather widget
