Android Lurker
New Galaxy S 2 / Problems with Kies Air
I just got my phone but I can't seem to connect to my pc through kies air. I get to obtaining ip address then nothing seems to happen. After, it says the "router addy: disabled, wep secure". Since it says disabled does that mean my wifi connection isnt setup? If so how would I go about doing that. Its kind of hard because I live in Japan with a aterm warpstar router so no idea where the wifi options are.
08-04-2011 07:40 PM
# ADS
Super Moderator/RS
DO NOT WRITE IN THIS SPACE
Android Lurker
I had this same problem, watched Kies connect once, but never connected again, kept stalling. Tried Mozilla, Chrome and Explorer, all with the same result. Then I noticed lots of Java icons stacked up in the taskbar, and under closer inspection, lots of instances of java started in the task manager.
Turns out the problem is the Java cache on your PC, it doesn't clear after you drop the connection, and prevents further re-connection attempts. Uninstall the Java on your PC and it all works fine. Not sure what you need to do if Java is essential to you.
Super Moderator/RS
Use Odin. Go to youtube and type in search "how to use odin".
