LG home application glitch--LG Genesis
This is a discussion on LG home application glitch--LG Genesis within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hello Rescue Squad! My phone is an LG Genesis, stock, not overclocked or modded in any way. My problem is my lg home application: since ...
Thread: LG home application glitch--LG Genesis
    Android Lurker emkf's Avatar
    Hello Rescue Squad! My phone is an LG Genesis, stock, not overclocked or modded in any way. My problem is my lg home application: since I got my phone, it has been acting up, giving me an error message at seemingly random times that says something to the effect of "lg home has unexpectedly stopped running", leaving me no choice but to force close, then click my home button and let it reload again. This has happened on several occasions now and I've only had my phone for a few days. It has happened while I was using another application in the foreground, and that application was usually still able to run without lg home stop app running. It has happened while I was browsing the internet, market, or even just moving from homescreen to homescreen. I've considered the possibility that one of my other applications may be the problem, but how will I know which one? I also thought that I might have overloaded my home screens, so I pared down from seven screens to the lowest number of five and reduced the number of widgets and apps, yet still no success. I am now thinking of clearing the data in the home app or restoring my phone to factory settings, but these are my last resorts. If anyone knows anything about this problem, I'd love to hear your suggestions. I'm sorry if this issue has already been addressed, I combed the site and the internet and couldn't find any info. Thank you for reading my post and any help you can give!
    Somewhere on Kamino
    83 times
    Either contact us cellular or lg. They are the ones that will either fix or replace your phone. It's a problem with the software.
    197 times
    FurryVarmint
    +1 to what Slag It! said. Only other option would be a try a factory reset, but that would be a major pain.
    DO NOT WRITE IN THIS SPACE
  1. Welcome to the LG Genesis Forum on Android dot net!
    By danDroid in forum LG Genesis
    Last Post: 05-13-2012, 08:49 PM
  2. LG Genesis appears on LG.com
    Last Post: 05-23-2011, 01:26 PM
  3. LG Genesis appears on LG.com
  4. Replies: 0
    Last Post: 05-23-2011, 11:32 AM
  5. Replies: 1
    Last Post: 05-11-2011, 11:24 AM
factory reset lg genesis
hard reset lg genesis
how to reset an lg genesis
lg genesis apps
lg genesis glitch
lg genesis hard reset
lg genesis issues
lg genesis problems
lg genesis reset
lg genesis troubleshooting
lg genesis updates
lg home application
overclocking lg genesis
problems with lg genesis
problems with the lg genesis
