How to conserve g2x battery power....not ALL about task manager
This is a discussion on How to conserve g2x battery power....not ALL about task manager within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; hey guys so the g2x is a great phone and i love it alot..however the battery power isn't the best.. i dealt with this same ...
Thread: How to conserve g2x battery power....not ALL about task manager
    Android Lurker beetlejuice26's Avatar
    hey guys so the g2x is a great phone and i love it alot..however the battery power isn't the best.. i dealt with this same problem with my g1.
    so ive heard alot of arguments with using and not using task-managers..since you guys are the pros, what are your opinions?
    if task managers aren't the way to go, are there other apps to help conserve my battery?
    i keep my gps off, wifi, etc, and i dont allow continuous syncing with programs. i also turn brightness all the way down. are there other ways to conserve battery?
    are there any other company's that make the g2x's battery but a higher mah because the g2x only has a 1500 mah battery..
    Android Lurker tenkan's Avatar
    hi there yes you can get a longer lasting battery for your lg2x its a extended 3500mAh get it from here Wholesale lg 2x Gallery - Buy Low Price lg 2x Lots on Aliexpress.com
    word thanks man.. do you know if there are smaller versions of the 3500mah batteries?
    and anyword on other programs to conserve battery or about the task managers
    Somewhere on Kamino
    83 times
    Easiest solution. Turn off gps, wifi when not using, dump all unnecessary apps (task killers, battery savers, and any anti virus app), and adjust your brightness.
    yep ive done that.. i heard something about switching the the gsm network only
    Yea you can turn off 3g and just use 2g but no internet with that setting,have you set a up a test at all to see how long your battery will last on differnt settings?
    Sent from my LG-P970 using Android.net
  1. Replies: 3
  2. Replies: 19
    Last Post: 06-11-2011, 05:40 PM
  3. Launcher pro issue with the task manager
    By davidjwclark in forum Samsung Fascinate
    Last Post: 01-27-2011, 09:33 AM
  4. task manager
    Last Post: 09-04-2010, 01:53 PM
battery saver g2x
best app killer for lg g2
best app killer for samsung g2x
best battery saver for lg g2
best task killer on g2x
g2x battery app
g2x saving battery
how to save battery on g2x
how to save power on g2x
how to set gt2x battery saver
lg g2 task manager
lg g2x powersaving
lg g2x task manager
task killer g2x
task manager on g2x
