LG Ally Broken Screen; External monitor?
This is a discussion on LG Ally Broken Screen; External monitor? within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hey guys. Today while I was at work, I dropped my LG Ally and the screen broken completely. All that shows up on it is ...
Thread: LG Ally Broken Screen; External monitor?
    Android Lurker shackd0ffmymelon's Avatar
    Oct 2011
    Hey guys. Today while I was at work, I dropped my LG Ally and the screen broken completely. All that shows up on it is several blue streaks. I can hear texts coming in and I can receive calls, but cant see ANYTHING. No I am not rooted. I was wondering if there was a way to view my phone screen on my PC. I cant see anything on the phone, so I'm not sure what I would do. I cant download any apps either. Is there a program I can use to access my screen via USB? I would basically like to check what text messages I recieved. Thats my biggest concern because my boss always texts me.
    Any help would be appreciated! Thank you!
    Android Lurker cogeary's Avatar
    Oct 2011
    Hm... you would need to enable USB debugging in order to get something like that to work. I'm not sure how you could do that without seeing the screen.
    If, for some reason, you already had USB debugging enabled:
    -Download and install the android SDK. There's some good instruction on the web.
    -Navigate to the tools folder of wherever you installed the SDK. (i.e. if you installed the SDK in C:\xyz the folder would be C:\xyz\tools)
    -Double-click the file called "ddms.bat".
    -A black box will appear. This will mean it's loading. Wait until the actually program (GUI) opens up.
    -If you have USB Debugging enabled then you should see your device listed (It's name will just be a random string of numbers and letters). Click on your device's name. Then select device->screen capture. A picture of what's on your screen will show up. Press the "refresh" button to get what's currently on your screen, press "save" to save the picture, and press "done" to cancel.
    I hope this helped. Good luck!
  1. Is There a Way to Pull Texts from Your Phone to PC? (Broken Screen)
    By marcotheclepto in forum HTC Thunderbolt
    Last Post: 03-06-2012, 10:30 AM
  2. Replies: 1
    Last Post: 09-05-2011, 11:19 AM
  3. LG ALLY Screen help
    By scgeekgirl in forum LG Ally Help
    Last Post: 08-29-2011, 10:35 AM
  4. While launching android emulator ubuntu screen pixels broken
    By syedshakeel2004 in forum Android Forum
    Last Post: 04-04-2011, 05:39 AM
  5. ally as external modem?
    By dishmonkey in forum LG Ally Help
    Last Post: 11-12-2010, 11:17 AM
android external monitor
android screen broken how to use external monitor
broken phone screen external monitor
broken screen lg ally
lg ally blue screen
lg ally broken screen
lg ally broken screen pictures
lg ally external display
lg ally screen
lg ally screen black
lg ally screen droped
lg ally to monitor
my lg ally screen is black
see ally phone screen on computer
use android device as second monitor usb screen broken
