Droid 1 Boot Loop
This is a discussion on Droid 1 Boot Loop within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; My original Droid is stuck in a boot loop where it won't load past the M logo. It loads up, shows the M logo for ...
Thread: Droid 1 Boot Loop
    Android Lurker Vito2000's Avatar
    Oct 2011
    Droid 1 Boot Loop
    My original Droid is stuck in a boot loop where it won't load past the M logo. It loads up, shows the M logo for a little bit, then shuts itself off. This happened after trying to flash a new kernel using kernel manager. At the time I was running CM 7.1.0 Stable with the stock CM7 kernel.
    I've searched the various forums and tried everything that I can to fix the issue, but to no avail. I'm hoping someone here can help me pinpoint the issue and fix it.
    Things I've tried:
    - Wiping the Dalvik cache
    - Wiping all data
    - Factory reset
    - Nandroid restore
    - Flashing different CM7 ROMs
    - Flashing different kernels
    - Formatting my SD card
    - Booting without the SD card
    - Flashing the stock .sbf files using RSDLite one at a time starting with the most current (FRG83G) and working my way backwards. None of the stock files worked UNTIL I flashed ESE81. ESE81 works fine and is currently loaded onto my phone.
    If I allow the OTA update of FRG01B to be installed on top of ESE81 I get the boot loop again.
    I read where someone else had an issue with their internal partitions being formatted improperly and I'm wondering if I have a similar issue. I'm also wondering if the ESEXX builds handle internal partitions differently than FRGXXX builds and that's why the ESEXX builds work on my phone when nothing else does.
    I should also note that I have never used sbd shell so if the solution requires that tool, it will have to be explained to me.
    Any suggestions? Things I haven't tried that I should try?
    Oct 2011
    Quote Originally Posted by Vito2000 View Post
    Things I've tried:
    - Wiping all data
    - Factory reset
    - Nandroid restore
    Ok - I was able to get this fixed. It was suggested by someone else that I flash this file to my phone: http://ted.servepics.com/nap/droid/M...-ota-50454.zip
    I did so but it did not seem to work UNTIL I flashed it a 2nd time. Worked like a charm. Problem solved.
  1. Locked Boot Loader On Droid 3
    By Preach2k in forum Android News
    Last Post: 07-07-2011, 11:19 PM
  2. Android Gallery: Infinite Loop
    By jsliu111 in forum Beginning Developers
    Last Post: 05-04-2011, 07:10 AM
  3. Droid X boot loop
    By Rangerwolf in forum Rescue Squad Help
    Last Post: 02-27-2011, 12:14 AM
  4. Droid X boot loop
    By Rangerwolf in forum Motorola Droid X
    Last Post: 02-26-2011, 12:36 AM
droid 1 boot loop
droid 1 boot loop fix
droid 1 bootloop glitch
droid 1 stuck in boot loop
droid 1 stuck in bootloop
droid a855 boot loop
droid a855 stuck on motorola logo
frgxxx
how to fix a motorola droid a855 problem rebooting
moto a855 boot loop
motorola a855 boot loop
my droid a855 stuck in loop at startup
og droid boot loop
og droid stuck at motorola logo
og droid stuck in boot loop
