motorola i1. MESSED UP!!!!
This is a discussion on motorola i1. MESSED UP!!!! within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; so i rooted my motorola i1 from boost mobile and all was well until i decided to uninstall my os message system because it was ...
Results 1 to 10 of 11
Thread: motorola i1. MESSED UP!!!!
    Android Lurker jdmdeco's Avatar
    Nov 2011
    so i rooted my motorola i1 from boost mobile and all was well until i decided to uninstall my os message system because it was sending dubble messages because of the handcent download i was using. then i tried to fix it and messed it all up. i tryd to do master reset and clearing everthing other than the BP setting. i tryd to do a reboot and now the phone wont even turn on it just gets stuck at the motorola M uploading screen... ROOTING is not for me. PLEASE HELP i use my phone for business. i think i need to redo the whole OS or somthing
    Administrator wicked's Avatar
    San Jose CA.
    259 times
    wwickedd
    How did you delete the stock messaging app?
    Somewhere on Kamino
    83 times
    Yes, what wicked is asking. What did you do and how did you do it?
    197 times
    FurryVarmint
    Why didn't you just turn off the notifications in the stock app and just use the Handcent notifications?
    DO NOT WRITE IN THIS SPACE
    Nov 2011
    i have no idea why i didnt think of the notification thing and i was rooted and had superuser permission. it was still working for calling after that but i went to the master reset then it got stuck in the moto M start screen and wont do anything. i dont know much bout fixing it but im good with instructions. cant i just d-load the moto drivers on my laptop for usb charging and then put android on it?
    197 times
    FurryVarmint
    First off, never do a system reset while missing a stock app. This is what happens.
    Secondly, the only way to recover the phone is to either use ADB to push the app back and hope another factory reset will fix the issue or reprogramming the phone. Since you mentioned reprogramming, I'll continue in that vein since it's simpler than using ADB.
    Reprogramming is usually called "SBFing" if you're talking Motorola phones. It's done via a program called RSD Lite with a file called SBF. We don't know what SBF stands for, so don't ask. I'm unsure if there exists the proper SBF to reprogram your phone since I've been unable to locate one. What carrier do you have your phone on?
    Nov 2011
    im going thru boost. oh the only screen that will come up other than the BOOT motorola M says
    msm 0b.20
    zeus p80 s14
    m0 r03
    ap prd bp prd
    vid 4d1504bb
    15ie24
    flash 20bc
    err: a5,62,63,01,32
    battery ok
    ok to program
    connect usb
    data cable
    197 times
    FurryVarmint
    That's the bootloader; it's where you'd flash the SBF if one existed.
    I've searched and come up with nothing. I'm afraid if you can't get into recovery and attempt another factory reset (which will probably have the same effect as the last one but is still worth a try) then your only option is an insurance claim. Sorry. I wish I had better news for you.
    Somewhere on Kamino
    83 times
    +1 i agree with fbm. Not sure if you can get a replacement through a claim but, its worth a try.
    Nov 2011
    ok thank you for all your effort guys....so if i bought the phone from a friend and then rooted it is there still a chance of getting an insurance thing?
  1. Keyboard dying or some messed up setting?,...acting strange?
    By Blackhood in forum LG Ally Tutorials & FAQ's
    Last Post: 12-23-2011, 10:31 AM
  2. Replies: 0
    Last Post: 08-01-2011, 12:46 PM
  3. Replies: 2
    Last Post: 05-06-2011, 12:00 AM
  4. Methinks That I Messed Up (Can't UnRoot EVO 4G).
    By NLAlston in forum Android Rooting
    Last Post: 05-03-2011, 01:27 PM
  5. I think I messed up something
    By Bridgett30 in forum LG Ally Help
    Last Post: 01-11-2011, 05:58 PM
err:a5,62,63,01,32
hard reset motorola i1 boost zeus p80
how do i hard reset if i get zeus flash on my motorola i1
missing android operating system i1 motorola
motorola i1 battery ok ok to program connect usb data cable
motorola i1 err:a5,62,63,01,32
motorola i1 sbf
motorola i1 stuck on main screen
motorola i1 wont power on
motorola i1 wont turn on
motorola xprt stuck on boot screen
my motorola h76xan9jr9an by boostmobile wont boot up
my motorola i1 wont turn on
rooted motorola boost xprt stuck in reboot
s blank zeus motorola i1
