High Ram Usage Issue
This is a discussion on High Ram Usage Issue within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi guys I got my Samsung Galasy S II GT-I900G about a month ago, I've been turning it off every night so that It can ...
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By wicked
  • 1 Post By antihero
Thread: High Ram Usage Issue
    Android Lurker Awesomenessof96's Avatar
    Jan 2012
    Exclamation High Ram Usage Issue
    Hi guys
    I got my Samsung Galasy S II GT-I900G about a month ago, I've been turning it off every night so that It can charge. Like a week ago for some reason I didnt and in the middle of the next day the RAM got to about 560MB/0.91GB and then after a while it got stuck while i was sending an SMS. I had to take the battery out and and turn it on for it to start working again. I'm not that much of a hardcore gamer or phone user. I dont know why my phone would do this. I have deleted all my apps and still the same problem so its definetly not a leaky app. It gets stuck and then i have to take the battery out !
    My phone has 2.3.4 android version
    If you need any other information, let me know and i'll post it... But PLEASE help me.
    I'm desperate here
    Jan 2012
    Anyone guys? Please?
    Administrator wicked's Avatar
    San Jose CA.
    259 times
    wwickedd
    Have you tried a factory reset?
    Awesomenessof96 likes this.
    Android Lurker antihero's Avatar
    Jan 2012
    Yea I'd say factory reset or check your processes and see what's drainning it.a good app to free ram and check your system usage is. "Android assistant" and it's free.
    Sent from my PG86100 using Android.net
    Jan 2012
    Thank you for replying
    I'm using android assistant...it not really helping :/
    and I dont want to lose all my stuff.. Like sms threads and contacts...and other things on phone
    Jan 2012
    No problem. Well a reset is the best bet just back up everything to your sd card using backmeup pro or a few other back up apps and you won't loose anything.good luck; D
    Jan 2012
    I use the app "days" on my phone a lot...so its filled... :/ Will backmeup also back that up??
    San Jose CA.
    259 times
    wwickedd
    For backing up messages, I use SMS Backup. Works great. Your contacts are tied to your gmail account so it should sync up after the factory reset. Or you could export contacts to SD card by opening up contacts, menu->export to sd card and it will save it as a .csv file.
    Jan 2012
    Yea it will back that up
  1. Sprint issue or Droid issue?
    By geetarmikes in forum Sprint
    Last Post: 06-08-2011, 02:21 PM
  2. All around Data Usage app?
    By Merlin Coryell in forum Motorola i1
    Last Post: 04-04-2011, 04:10 PM
  3. All around Data Usage app?
    By Merlin Coryell in forum HTC EVO 4G
  4. Data Usage on WiFi?
    By Blackwood in forum LG Ally Help
    Last Post: 01-10-2011, 09:48 AM
android high ram usage
android ram issue
android ram issues
android ram problem
android ram problems
android ram usage high
droid razr high ram usage
droid razr ram usage
high ram status droid
high ram usage android
razr ram usage
why is my phone ram so high
why is my ram so high on my android
why is my ram usage so high android
why is my ram usage so high on android
