Applications not caching data
This is a discussion on Applications not caching data within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; This is the second time this has happened and what worked before isn't working now. My LG Phoenix (LG P505) has decided that the applications ...
Thread: Applications not caching data
    Android Lurker SlackerEmeritus's Avatar
    Feb 2012
    My LG Phoenix (LG P505) has decided that the applications won't cache data so it can be easily cleared; they go right into application data instead, sitting there and clogging up the phone's memory. Last time this happened, clearing all application data (and then having to reenter accounts and bookmarks for everything) seemed to have done the trick. No such luck this time round.
    Evsn using App Cache Cleaner does nothing since the data isn't in cache. Has anyone else with a Phoenix or an Optimus run into this? Does anyone have tips or advice?
    Administrator wicked's Avatar
    San Jose CA.
    259 times
    wwickedd
    Hmm, I don't have a clear solution for this other than a factory reset, hopefully someone who knows will chime in here. Best of luck!
    Somewhere on Kamino
    83 times
    Do you have task killer installed?
    Feb 2012
    I do not have Task Killer. D'you think it'll help, then?
    _
    I have gone to look for myself. If I should return before I get back, keep me here.
    Somewhere on Kamino
    83 times
    No, task killer is not a good thing. Only time it is needed would be to remove an app that through normal means is not possible. Meaning you cannot just uninstall.
  1. Replies: 1
    Last Post: 01-19-2012, 07:08 PM
  2. hidden applications
    By XeeR in forum Android Forum
    Last Post: 10-23-2011, 04:22 AM
  3. hidden applications
    By XeeR in forum Samsung Galaxy S2 AT&T
    Last Post: 10-21-2011, 02:00 AM
  4. corrupt applications
    By allybi in forum LG Ally Help
    Last Post: 10-30-2010, 09:34 PM
  5. LG Ally Applications
    By RedFox in forum Introductions & Site Assistance
    Last Post: 09-18-2010, 08:56 AM
android upgrade lg phoenix p505
apps not working on lg phoenix
at&t lg phoenix not responding after update
how do i get to cache on the lg p505
how do i kill apps on the lg phoenix?
lg-p505 cache
my p505 wont install apps
