i need help
This is a discussion on i need help within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; hiiiiiiii bro how to get android market Account...
Results 1 to 8 of 8
Thread: i need help
    Android Lurker ahmadarabiat's Avatar
    Feb 2012
    Exclamation i need help
    Somewhere on Kamino
    83 times
    Go into market on android device and sign in.
    Super Moderator 252chevyboyz's Avatar
    North Carolina
    13 times
    jfhrtn
    Are you on a mobile device? Computer?
    Sent from my Liberated D2
    Droid 2/Liberty 2.0.1/Oc'ed/1.3ghz
    Visit our sister site Droidforums.net for more info
    Feb 2012
    Thanks but when i press install in market
    There are no Android phones associated with this account. Please sign in with a different account.
    What should I do
    Somewhere on Kamino
    83 times
    If your using a computer then it will not.
    Feb 2012
    Thanks man butI use kindle fire Maybe thatsthe
    problem
    help me
    Android Sr Member CoolDroid's Avatar
    Feb 2012
    9 times
    Open your phone Android market app, then if you already have a Google account then log-in, if you don't have then sign-up using market app. If you already enable Google's second verification then generate application specific password and use it instead of your real password.
    Feb 2012
    9 times
    Quote Originally Posted by ahmadarabiat View Post
    What should I do
    Very first time you need to log-in Android market using your phone app, then you can remotely install apps using desktop PC that you mention this thread. You can't download apps on the android market directly to your computer hard disk. But you can remotely download them to phone using computer.
z4root download
