WiFi Sync
This is a discussion on WiFi Sync within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; samsung galaxy s won't sync email when connected to wifi. is there a wifi setting that i have missed?...
Results 1 to 10 of 11
Thread: WiFi Sync
    Android Lurker mgivens's Avatar
    Feb 2012
    Angry WiFi Sync
    Android Enthusiast Skunk Fox's Avatar
    5 times
    Not Wi-Fi. Check the e-mail application's you are using, settings.
    Feb 2012
    in account settings now. it is an exchange server that i'm needing to sync with. sync's fine when not connected to wifi.
    5 times
    Try to unckeck "auto-sync" in settings and check it again. Also, did you try restarting your phone. Was it always like this or just now?
    Feb 2012
    tried changing the settings. get "unable to connect to server" message while connected to wifi. turn wifi off and it sync's perfectly.
    5 times
    What about the browser? Does it work when you try to sign in to your e-mail through the browser?
    5 times
    Try to wipe the data and cache of the app. Maybe this could help.
    Feb 2012
    tried to access through webmail without success.
    Feb 2012
    do i need to "use packet date" when connected to wifi?
    5 times
    It didn't work through the browser either? That's awkward. Is it Gmail, right? Try contacting their troubleshooting service, as this might be Gmail's problem.
  1. Can't turn wifi off after turning on wifi direct. please help
    By Franklin in forum Samsung Galaxy S2
    Last Post: 12-23-2011, 01:41 AM
  2. Background Data Sync and Auto Sync....
    By nicolett80 in forum LG Ally Help
    Last Post: 03-25-2011, 03:13 AM
android 4.4.4 unable to sync via wifi
android phone wont synce email when on wifi
android won't sync with home wifi
email won't sync on wifi
email. wont sync over wifi on email app
emails will only be sent over wifi on samsung galaxy 4
galaxy s4 wont sync over wifi
gmail won't sync over wifi
s4 email sync wifi
s5 wont update email unless on wifi
samsung device doesn't sync email when using wifi
samsung galaxy s4 unable to connect to server while connected to wifi
samsung galaxy s5 can only send emails when connected to wifi
samsung galaxy s5 email syncs only on wifi
sync email wi-fi only android
