Android Lurker
Data Connection Drops When Phone Sleeps
My G2 recently developed an issue where the data and/or wifi connection shuts down when the phone is not in use. When I wake the phone up the signal icon and wifi icon in the notification bar is often white for a short time and then, sometimes after a minute or two, switches to green. A T-Mobile rep told me that when the signal icon is white I am not connected to the data network. Can someone shed some light on what might be wrong, what troubleshooting I can do?
Thanks!
Phone: G2
software version: 2.3.3
02-19-2012 07:25 PM
# ADS
Android Jr Member
Hi!
Are you use any automatic data disable app like "Battery defender" or "Juice defender". If so those app can ability to disable data and WiFi connection when phone is sleep. Also battery saver can do it. So check those apps settings.
update feedback!
Android Lurker
unfortunately I do not have any battery saver or Juice Defender software on my phone. I actually run it full on and plug in frequently.
Android Jr Member
Originally Posted by
JRFwolfie
sorry friend i don't have no idea about this situation. :D Hope someone help you!
Super Moderator/RS
Have you ever yanked your battery out? Do you have an app or task killer on it? If it just started and never happened before what have you recently changed on it?
Super Moderator/RS
Do you have the WiFi policy set to never go to sleep?
DO NOT WRITE IN THIS SPACE
Super Moderator/RS
Thanks fbm that was my next question.
Android Lurker
tell me how to check wifi policy not to sleep. I have looked at all the settings I can find and do not see a "do not sleep" setting. Great idea, I hope!
Super Moderator/RS
Settings> Wireless & Networks> WiFi Settings> Menu Button> Advanced> Wi-Fi sleep policy> Never
At least that's how I got to mine. :-)
Android Lurker
From Wolfie to my furbearing friend... THANKS!!!
Somehow it was set to turn off when the screen did. Problem solved
