Problems with Motorola XT860
This is a discussion on Problems with Motorola XT860 within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi, I recently purchased the Motorola XT860, but can not seem to add contacts to the phone book. The only contacts that I have are ...
Thread: Problems with Motorola XT860
    Android Lurker Lorraine1969's Avatar
    Feb 2012
    Newfoundland, Canada
    Angry Problems with Motorola XT860
    Hi, I recently purchased the Motorola XT860, but can not seem to add contacts to the phone book. The only contacts that I have are 4 that was added to the favorites menu which is displayed at the front page of the phone. I do not want to add contacts from Facebook or any other social media, I just want to add phone numbers from those I choose. I have went through the basic "tips and tricks" video and read the users manual, but nothing seems to work.
    I was wondering also, if anyone has any problems with the phone shutting down periodically, or freezing up to the point you have to remove the battery? What I thought was an awesome phone, has proved to be a major headache for me!!!
    Android Jr Member mamawm's Avatar
    mississippi
    14 times
    I'm not familiar with your model but I would assume that adding contacts to it will be much the same as on my Motorola droid bionic. There are 2 ways to go about it. First go into the app drawer and select the contacts app. Then hit the menu button, select more, then settings, then contact storage, select google and check remember this choice, then click OK. Next hit your back button to go back to the contacts list. There is a + sign in the upper right corner, click it and enter your info. The second way is to open Gmail on your pc and enter your contacts from there.
    Sent from my A100 using Android.net
    197 times
    FurryVarmint
    I'll attest to the freezeups being a major issue. A lot of them are related to MotoBlur, which is a "skin" Motorola put on your phone in order to customize it and make the phone's user experience more desirable. Unfortunately many of the apps aren't well-coded and there are problems.
    Check to see if there are any updates for your phone via the settings. I can talk you through it if you would like.
    DO NOT WRITE IN THIS SPACE
    Feb 2012
    Thanks for the replies!
    What should have been a quick and painless process for add contacts (which I knew how to do) turned into a pain in the behind. Finally, I got p.o'd enough with it, that I set my phone back to factory default. Well low and behold...everything is working fine now! I added the contacts, re-downloaded the very few apps that I had..upgraded what needed to be upgraded and voila!, everything seems to be working fine!!
    197 times
    FurryVarmint
    Wonderful!
    I hate to say it but sometimes you just have to reset the phone. It stinks like broody poop (if you know anything about chickens you know what I'm talking about), but it needs to be done from time to time. Much like sometimes you just have to reinstall Windows/OS of your choice on your PC. Skinned phones (MotoBlur, HTC Sense, Touchwiz) are more likely to need it because the "increased functionality" apps built into the OS by the OEM make it much more likely to glitch.
    If you have any problems, you know where to go now, eh?
    Feb 2012
    Yes I do!
    So far, so good!! haha
  1. Motorola i1 Problems
    By danDroid in forum Motorola i1 Tech Support
    Last Post: 05-19-2012, 07:59 PM
  2. Motorola XT860 4G Announced
    Last Post: 07-18-2011, 02:01 PM
  3. Replies: 0
    Last Post: 07-18-2011, 12:23 PM
  4. Welcome to the Motorola XT860 4G Forum
    By danDroid in forum Motorola XT860
    Last Post: 07-18-2011, 11:04 AM
  5. motorola i1 problems
    By gigettebatista in forum Motorola i1
    Last Post: 10-08-2010, 08:16 PM
motorola xt830c
motorola xt830c problems
motorola xt860 4g locked up wont open
motorola xt860 contact problem solve
motorola xt860 freeze
motorola xt860 freezing
motorola xt860 keeps rebooting
motorola xt860 keeps shutting down
motorola xt860 problems
motorola xt860 troubleshoot
motorola xt860 troubleshooting
problem motorola xt860
screen frozen motorola 860 phone
why is my xt860 rebooting
xt860 problems
