GPS Not Working on Photon Helllppp!!
This is a discussion on GPS Not Working on Photon Helllppp!! within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; WHEN I GO TO USE MY NAVIGATION (NOT THE TELENAV, I HATE THAT ONE, BUT THAT DOESNT WORK EITHER) I GET A MESSAGE AFTER I ...
Thread: GPS Not Working on Photon Helllppp!!
    Android Lurker shannon539's Avatar
    Feb 2012
    Angry GPS Not Working on Photon Helllppp!!
    WHEN I GO TO USE MY NAVIGATION (NOT THE TELENAV, I HATE THAT ONE, BUT THAT DOESNT WORK EITHER) I GET A MESSAGE AFTER I TYPE THE ADDRESS IN THAT SAYS "SEARCHING FOR SATELITE SIGNAL" I HAVE WAITED UP TO 40 MINS AND GOTTEN NO SIGNAL STILL! MY PHONE IS LESS THEN 2 MONTHS OLD AND I HAVE DONE A HARD RESET AND PRL UPDATE WHICH STILL HAVENT WORKED. i DO HAVE INSURANCE THRU RADIO SHACK WHERE I PURCHASED IT BUT DOES ANYONE KNOW HOW I MIGHT FIX THIS PROBLEM SO I CAN USE MY GPS?? THANKS!
    Somewhere on Kamino
    83 times
    Wow, what's with the Billy Mays post? As far as your phone is concerned have you called into Sprint yet? Just a thought. Also, if you tap your menu then settings and then location security; is the use gps satellites turned on? What about the option for using wireless networks? If both are checked have you swiped down from top of phone to bottom to verify gps is on? Just a few things to check.
  1. Photon 4G to 3G issues
    By Myke in forum Motorola Photon Tech Support
    Last Post: 11-16-2011, 07:20 AM
  2. Photon Issues
    Last Post: 10-05-2011, 10:01 AM
  3. First thoughts of the Photon
    By danDroid in forum Motorola Photon
    Last Post: 08-25-2011, 11:31 AM
  4. Motorola Photon 4G
    By acoleman1981 in forum Sprint
    Last Post: 08-25-2011, 11:29 AM
  5. Motorola Photon vs HTC EVO 3D
    Last Post: 08-12-2011, 09:09 AM
gps isnt working on photon
gps not working motorola photon
gps not working on motorola photon
motorola photon gps broken
motorola photon gps broken after update
motorola photon gps issues
motorola photon gps not working
motorola photon gps problem
motorola photon issues
motorola photon reset gps
photon 4g gps problems
photon gps stopped working
photon no gps
why does my gps not work on my photon
