Android Lurker
Message "Process com.android.settings Has Stopped Unexpectedly
Hi,
i'm a new android user and a new android.net user, so forgive me for something "out of its place"
I bought a used Samsung Galaxy S I phone and, when trying to set screen lock it shows the message
"The application Settings (process com.android.settings) has stopped unexpectedly. Please try again. And obligates me to "force Close".
Has anyone some idea why it can be happening? and how can i fix it?
I'm using this exemple, but it also happens somentimes with other things i try to do.
Tks!
03-05-2012 09:26 AM
# ADS
Android Lurker
Oh, i should have mentioned.
I've already reseted to factory settings and it didn't works.
Android Lurker
force close
I am to facing the same problem. Of android setting launched 2
can anyone help I have delete all the download. App
Android Lurker
Please,if anyone can help, the same message came up on my Android and now my phone wont ring when someone calls. Please help us! Thank you.
Rescue Squad
Is everyone that is having the issue have the same phone as the OP? Also, are all of you rooted? If so, what ROM?
Sent from the God of phones.. Thunder... THUNDER... THUNDERBOLT!!
Android Lurker
Hi Thunderbolt. I have the android ZTE990G. I am so new to this kind of phone that I dont know what OP or ROM means. Please forgive me. All I know is, for some reason, my phone wont ring and if I try to use the button on the side of my phone to turn the volume up/down or vibrate, my phone turns off.
Thanks, Radar.
Sent from my ZTE-Z990G using Android.net
