Onda Vi40 Elite Flash Support Missing
This is a discussion on Onda Vi40 Elite Flash Support Missing within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I bought an Onda Vi40 Elite 9.7 Inch IPS screen Android 4.0 ICS A10 Tablet direct from China. The Tablet is good except it does ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By pedroariel
Thread: Onda Vi40 Elite Flash Support Missing
    Android Lurker dynamata's Avatar
    Mar 2012
    I bought an Onda Vi40 Elite 9.7 Inch IPS screen Android 4.0 ICS A10 Tablet direct from China. The Tablet is good except it does not support Flash & will not play YouTube videos, also FLV files will not play despite being supported in the specs:
    Flash: No
    Video: 1080P HD Support 3GP, MP4, FLV, MPEG 1/2/4, AVI, MPG, AVI Format
    According to dealer tech support an O.S upgrade will not enable Flash, I like the Tablet & don't want to return it. Is there any way to resolve these issues, will Flash support be available for Android 4.0 in the near future?
    Android Lurker pedroariel's Avatar
    Mar 2012
    hello, to enable full flash support on onda vi40, first update to the latest vi40 firm ware v.08, intall adobe flash player from market, finally install opera mobile and enjoy full flash support.
    dynamata likes this.
    Mar 2012
    I found a guide here:
    Colonel Zap's Blog: Onda Vi40 Firmware Flashing Guide by Francis
    Do you know of any others?
    197 times
    FurryVarmint
    That looks like it should be all you need. What problem are you having?
    DO NOT WRITE IN THIS SPACE
    Mar 2012
    Do I Launch the Livesuit with the Tablet connected to the PC?
    My Tablet came with full Android Market, will upgrading the firmware to v.08 remove it & if so how can I backup & restore
    Model: Onda Vi40 Elite Edition (ONDA MID)
    CPU: All Winner A10, 1GHz,(up to 1.5GHz maximum) Cortex A8;
    GPU: Mali 400
    OS: Android 4.0.3 ice cream sandwich
    Baseband Version 0.6
    Kernel Version 3.0.8+
    lgm@XServer #1
    Build number:
    crane_m1003h6-eng 4.0.3 IML74K eng.lgm.20120117.161554 test-keys
    SN V140AC1V3A02323
    Mar 2012
    I installed the USB driver that came with the upgrade package but Windows 7 is giving me "USB device not recognized" when I connect the tablet.
    Mar 2012
    The culprit was a USB hub. I bought an A4Tech Hubmaster 4 port USB Hub (with PS2 connectors and audio jacks) from Maplin Electronics in London. Although the Hub charged my mobile phone & recognized the wireless keyboard, it would not read my iPod or USB stick so I returned it. The sales assistant persuaded me to exchange it, this time it read the USB stick but not the the iPod however I decided to keep it.
    Whenever the Tablet was connected to the PC, Windows would not recognize it & gave error messages when I tried to install drivers. I had been trying like for 2 days with drivers from various sources, as soon as the USB Hub was removed from the equation Windows recognized the Tablet & installed the USB driver. There was still an ! mark next to a USB device in Windows Device Manager so I installed one of the Onda drivers & it disappeared.
    The lesson here is don't use faulty hardware because you can get unpredictable results.
    Android Lurker shadowbellum's Avatar
    Mar 2012
    Hello,
    I just received my Onda Vi40 today, running ICS 4.0.1.
    I just can't get Windows7 Professional to recognize it. I tried 64Bit and 32Bit. Even a fresh installed Vista doesn't recognize it!
    Even if I choose the usbdrv File manually from the Livesuit Folder I just get "This device cannot start. (Code10)" from the Device Manager as an answer.
    I tried my Notebook and my normal PC, none works!
    In USB Storage Mode the Device shows just fine, but if I enable USB-Debugging I can't get it to work.
    Has anyone using Windows7 experienced this issue? I don't know what to do!
  1. Replies: 0
    Last Post: 10-04-2011, 12:19 PM
  2. No flash support for galaxy prevail?
    By dsturman in forum Android Forum
    Last Post: 06-26-2011, 01:54 AM
  3. does otimus s support flash, quick time mov
    By jerryw505 in forum LG Optimus S
    Last Post: 06-07-2011, 09:34 PM
  4. Flash Support
    Last Post: 02-16-2011, 02:08 PM
  5. HTC EVO 4G to Support Flash & HD Video Recording
    By DougDroid in forum Sprint Android News
    Last Post: 05-03-2010, 06:10 PM
flash player for onda vi40
flashplayer onda v40i
my onda mid android 4.03 not playing youtube videos
onda mid flash player
onda mid usb driver
onda mid vi40
onda mid vi40 flash
onda usb charge hub
onda vi40 adobe flash
onda vi40 flash player
onda vi40 usb driver
onda vi40 windows 7 driver
onda vi40 youtube dont work
usb device not recognized onda tablet
vi40 onda mid
