Messed Up Superuser
This is a discussion on Messed Up Superuser within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I got a Zenithink C91 with 4.0(it comes out of the box rooted) on it and i bought the superuser elite settings and downloaded superuser ...
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By Droid-Xer
  • 1 Post By dtb1987
Thread: Messed Up Superuser
    Android Lurker dtb1987's Avatar
    Mar 2012
    Messed Up Superuser
    I got a Zenithink C91 with 4.0(it comes out of the box rooted) on it and i bought the superuser elite settings and downloaded superuser 3 beta 4 and tried to flash it onto my C91. Now when ever i open my root only apps it says my device is unrooted a message i wasn't receiving before i tried to install superuser 3 beta 4. Things i've already tried:
    1. Flashing it again
    2. Installing the APK instead of flashing
    3. taking it back to factory default
    4. flashing the original version of superuser onto the device.
    As it is right now the device works but i would really like my superuser privileges back. If any of you have any ideas i would be most appreciative.
    Mar 2012
    I have Dev tools on it if that helps at all.
    Sent from my ZT ICS using Android.net
    El Paso, TX
    59 times
    _B0BB0_
    dtb1987 likes this.
    Mar 2012
    i`ve already tried that one thanks for the suggestion
    Mar 2012
    If anyone knows what files and folders superuser uses it might be helpful in finding out what exactly is broken
    El Paso, TX
    59 times
    _B0BB0_
    Try emailing the su dev ChainsDD and see what he says.
    dtb1987 likes this.
    Mar 2012
    I found the answer. If anyone else has this problem go to www.zenithink.com and download the newest updates and flash your device it did the trick for me
    Droid-Xer likes this.
    El Paso, TX
    59 times
    _B0BB0_
    Good stuff. Thanks for posting the solution.
  1. motorola i1. MESSED UP!!!!
    By jdmdeco in forum Rescue Squad Help
    Last Post: 12-26-2011, 01:00 AM
  2. Replies: 0
    Last Post: 09-26-2011, 12:06 PM
  3. superuser error
    By psal217050 in forum Rescue Squad Help
    Last Post: 06-20-2011, 04:47 AM
  4. I think I messed up something
    By Bridgett30 in forum LG Ally Help
    Last Post: 01-11-2011, 04:58 PM
android forums
how to install elite superuser
how to tell if superuser is messed up
super user beta download
superuser 3 beta
superuser 3 beta 4
superuser 3 beta download
superuser 3.0 beta 1
superuser 3.0 beta 1 download android
superuser 3.0 beta 4
superuser beta
superuser beta 3
superuser v3.0-beta(31)
superuser zenithink 4.0
zenithink rescue
