Android Jr Member
Cricket M860 Bloatware Help!!
Hi I need help identifing the bloatware apps my phone needs to operate normal. I don't want to delete the ones my phone needs. Here's the bloarware app list
Uno
Midnight bowling 2
Documents 2 go
MyAccount
Store front
Mobile web (not browser)
Poynt
Swype
Photobucket
Youtube
Thanks in advance (:
Sent from my M860 using Android.net
04-21-2012 08:54 PM
# ADS
Super Moderator
You want to be careful with *deleting* any of those apps. You're much better off using a program like Titanium Backup to freeze the apps, rather than deleting them.
Sent from my SAMSUNG-SGH-I777 using Xparent Blue Tapatalk
Android Jr Member
Will that clear some internal phone storage?
Super Moderator
No, the apps will still be physically there, but they won't appear in the directory and they won't load when you boot the phone. If it turns out that you do need them for some reason, it's simplicity itself to unfreeze them and put them back in service.
Android Lurker
But in theory if u freeze them and go a day or so without problems u should then be able to root uninstall right???
Sent from my Desire HD using Android.net
Super Moderator
Originally Posted by
tinee
Yes but if any official update comes through you won't get it. It is best to just freeze and hide them.
Dnay12
Yes.
-end of line-
Android Jr Member
Thanks guys
