Simple Install Problem From a Newby
This is a discussion on Simple Install Problem From a Newby within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I am having problems installing ADK on a Win 7 Home Premium 64 bit machine. The JDK and JRE both installed without issue. The path ...
Thread: Simple Install Problem From a Newby
    Android Lurker marcusjunod's Avatar
    May 2012
    The JDK and JRE both installed without issue. The path variable was set to include C:\Program Files\Java\jdk1.7.0_04\bin. An error message comes up stating "Java SE Development Kit (JDK) not found" when installing the Android SDK. Additionally stated, "Error: Failed to find Java version for 'C:\Windows\system32\java.exe': [2] The system cannot find the file specified."
    I verified that java.exe was located in the location stated and also observed that it was version 7.0.40.20.
    Any suggestions?
    Thanks.
    Marcus
    May 2012
    Fixed it!
    Simple problem requires, sometimes, a simple answer. The proper setting of JAVA_HOME makes all the difference in the world.
    Marcus
    Android Sr Member Frederuco's Avatar
    Sep 2011
    /EARTH/USA/NC/
    52 times
    frederuco
    Glad you got it sorted. Sorry we did not get to you sooner.
    Maybe next time.
    TransformerForums - Administrator
    AcerTabletForum - NexusTablets - AndroidTablets - Super Moderator
    Android.net - TransformerForums - Rescue Squad
    ASUS Transformer 16GB with Keyboard Dock - Cornerstoned and ICS-ified
    iP*one 4
    Just once I want someone to call me Sir without adding you're making a scene.
    - Homer Jay Simpson
    Android Lurker solo812's Avatar
    Jun 2012
    So what's the answer for the rest of us?
    Quote Originally Posted by marcusjunod View Post
    Marcus
    Come on man. Can you post your fix?
  1. Snapprize: simple new app
    By g.bailby in forum Android Forum
    Last Post: 10-27-2011, 04:14 AM
  2. I'm a newby 2
    By fjstriplin in forum Introductions & Site Assistance
    Last Post: 05-15-2011, 02:03 PM
  3. Newby here!
    By dvdman in forum Introductions & Site Assistance
    Last Post: 02-16-2011, 01:17 AM
  4. Another Android Newby here!
    By Txdistancerider in forum Introductions & Site Assistance
    Last Post: 02-15-2011, 04:45 PM
  5. Newby
    By billherbert in forum Introductions & Site Assistance
    Last Post: 12-30-2010, 01:20 PM
android failed to find java version
android failed to find java version for
android sdk failed to find java
android sdk failed to find java version
error failed to find java version for android sdk
error failed to find java version for c:\windows\system32\java.exe
error: failed to find java version for c:\windows\system32\java.exe
failed to find java version android
failed to find java version android sdk
failed to find java version for java.exe
google error: failed to get jre version.
