Android Lurker
Help
Question. Why do I not get a notification when I have a email sent to me? I always have to go into my email and hit refresh. Then the emails appear. I'm trying to get it to show a small notification on the top left corner like normal. Anyone having this problem? If so any way to fix that?
Thanks!!
Sent from my Galaxy Nexus using Android.net
05-04-2012 10:47 AM
# ADS
Super Moderator
Hello AndroidEric, and welcome to the forum!
When you say "email", are you referring to the Google G-Mail, or another type of email?
Super Moderator
Welcome. Yep which app are you using? You can go through the app settings to set up notification preferences.
Super Moderator
Don't forget to turn auto-sync on.
When people run in circles,
it's a very very mad world.
Tears for Fears
Android Lurker
Sorry. Gmail. I have looked under settings. And notification seems to be on. But I still don't get them. Unless I open and hit refresh.
Thanks for the warm welcomes!
Super Moderator
How often do you have it syncing? Like tears for fears said, ensure sync is on in settings/accounts
Android Lurker
It is now working . Thank you all.
Super Moderator
Android Lurker
Yes. That was the issue.
Thanks again.
Android Lurker
i don't know why my Samsung galaxy y doesn't work (screen) on my home computer only?
when i connect it to other pc screen works and i can choose android storage
can some one help me
