Light Leakage Help
This is a discussion on Light Leakage Help within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; I have an HTC rezound, where the edge of the glass meets the bezzel on the bottom, there is a considerably large amount of light ...
Thread: Light Leakage Help
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    7 times
    @milkmac9
    Light Leakage Help
    I have an HTC rezound, where the edge of the glass meets the bezzel on the bottom, there is a considerably large amount of light leaking to the bottom and sides from the capacitive buttons.
    my question is, is my screen raising up? and should I take it back and get a new one
    Motorola Droid RAZR MAXX - Droid X2
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    I would not hesitate to return this phone.
  1. LED Light Changes with new update.
    By HammerTime in forum LG Ally Help
    Last Post: 03-20-2011, 09:39 AM
  2. status light
    By mcorrente in forum LG Ally Help
    Last Post: 10-16-2010, 04:14 AM
  3. LED notification light
    By Nicole in forum LG Ally Help
    Last Post: 10-02-2010, 12:55 PM
  4. Status light
    By koosh_boy1 in forum LG Ally Apps
    Last Post: 09-25-2010, 06:09 PM
  5. indicator light
    By cdavies in forum LG Ally Help
    Last Post: 09-02-2010, 12:27 PM
android light leakage
android phone light leakage
bottom bezel light leak htc
does the htc rezound leak light
droid razr light leak
droid razr light leakage at bottom
htc rezound light leak
light leak on android
light leakage galaxy 3
light leakage on rezound
light leaking side of android screen
light.leakage htc rezound
razr light leakage
rezound capacative light leak
rezound light leakage
