Need Help Rooting/Recovery Use
This is a discussion on Need Help Rooting/Recovery Use within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Let me look into it, I'll get back at this. -end of line-...
Results 11 to 17 of 17
Like Tree3Likes
Thread: Need Help Rooting/Recovery Use
    Super Moderator RobKort's Avatar
    Apr 2012
    Pennsylvania, US
    71 times
    -end of line-
    Android Lurker chronicracer's Avatar
    Jun 2012
    thanks! Just to make surw you know. I'm NOT rooted. Android 2.3.5 hboot 2.18
    Jun 2012
    I hope yoy can help me. This thing is annoying me
    Apr 2012
    Pennsylvania, US
    71 times
    Well, here is the deal....
    You need to root your phone to get a custom recovery installed, and for that you really need a USB cable, so your first task is to get one from HERE which are very affordable.
    Once you get a hold of one there is a one click method I found over at XDA that seems to work well, and it works on Windows/MAC/Linux. Just make sure you follow the instruction to the letter and download all the necessary driver to enable your PC to see the device (everything you need is on the link). Make sure that you have Superuser installed after the procedure and update the su binary by opening the app, going to settings/su binary and update it. Even if it's up to date I always recommend doing it. Install Titanium Backup from the market and back up all your user and system app. TiBu/batch/scroll down to back up tab/select "back up all user apps+system data"/run batch
    After that, look into THIS link to install the custom recovery on the phone which also seems to have several methods to accomplish it, but I personally would use the ROM Manager method if you don't feel very comfortable with coding. Before you flash anything back up the current ROM in case anything goes wrong.
    I hope that helps getting you what you want.
    Edit/ If you are going to flash another custom ROM it is a good practice to wipe everything with the custom recovery. Boot into recovery/wipe data+cache+dalvik cache. Dalvik is normally on the Advance tab.
    Jun 2012
    Thanks man. I don't have internet at my house. I was hoping to avoid computer. But ill get it. Some how lol. Buy again thanks !
    Apr 2012
    Pennsylvania, US
    71 times
    No problem, just let us know if you need more assistance. But yeah, you need a PC, internet, and the USB cable to get anywhere.
    -end of line-
    197 times
    FurryVarmint
    Can't things be downloaded to the phone and transferred over? Or, worst case scenario, run something like PDANet or Easy Tether (again, downloading to the phone and transferring over) to get things right on the PC/Mac? A card reader can be had for like a buck on eBay if needs be.
    DO NOT WRITE IN THIS SPACE
  1. Recovery of Pictures?
    By nia796 in forum LG Ally Help
    Last Post: 02-22-2013, 01:08 AM
  2. Need Help Rooting/Recovery Use
    By chronicracer in forum Android Forum
    Last Post: 06-20-2012, 01:13 PM
  3. ClockworkMod Recovery for Captivate
    By moosefist in forum Samsung Captivate Hacking
    Last Post: 02-24-2012, 09:51 AM
  4. Hexamob Recovery Pro
    By wicked_attdroids in forum Sony Xperia Play
    Last Post: 07-19-2011, 05:44 AM
  5. Recovery Mode
    By suntech in forum LG Ally Help
    Last Post: 11-27-2010, 11:50 PM
bootloader only says parsing
captain throwbacks root method for 2.18
hexamob recovery pro free download
hexamob.com/rooting.html
hexamob.com/rooting.html droidx
rooting not detecting pc36img hboot 2.18
rooting says parsing
used htcdev to unlock evo 4g but still wont flash image
