Need Help Rooting/Recovery Use
This is a discussion on Need Help Rooting/Recovery Use within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hi recently I unlocked my EVO with HTC dev. I am unlocked running hboot 2.18 not sure of the other info. Android 2.3.5. I'm trying ...
Results 1 to 10 of 17
Like Tree3Likes
Thread: Need Help Rooting/Recovery Use
    Android Lurker chronicracer's Avatar
    Jun 2012
    Exclamation Need Help Rooting/Recovery Use
    I am unlocked running hboot 2.18 not sure of the other info. Android 2.3.5. I'm trying to root and I have read captain throwbacks stuff and he uses a computer. I don't have access to a working usb cable for mine. I have a cable it only charges now. It won't recognize my device. When I unlocked bootloader I borrowed my friends cable. But I can get to his cable anymore since I have moved. Anyways. Since yesterday I have been trying to get a custom recovery on my device. I prefer amon ra. And I used a few different ones only 1 kinda worked. But all the others say main version to old. And the one that sorta works just says parsing on the bootloader screen. Which if I'm correct is where I should be to update and install the custom recovery. I'm confused as to why nothing will work. I'm not worried about s-off I just want to put the recovery so i can flash super user and root my phone for WiFi tether. So if you can help me it would be greatly appreciated. it locates my files everytime. Some say main version to old. And others just say parsing... And nothing else. I name the files PC36IMG.zip like I'm supposed to and put it on the root of my SD which if I'm correct the root would be where android secure, dcim, download are located. Correct me if I'm wrong.
    197 times
    FurryVarmint
    Moved to proper forum.
    DO NOT WRITE IN THIS SPACE
    Jun 2012
    Thanks, sorry bout that I'm using my phone for this. I'm kinda in a rush to do this.
    Jun 2012
    Can anyone help me, im really annoyed by the issues I'm having.
    197 times
    FurryVarmint
    A link to the method you used would be helpful, as would telling us which phone in particular you have, and what carrier you're on.
    I understand the rush and frustration, but sometimes these things take time. Once I know exactly what phone/carrier you have I might be able to point someone in your direction.
    Jun 2012
    Well im not rooted I used HTC dev to unlock bootloader. I'm on Sprint and im using the evo 4g
    197 times
    FurryVarmint
    I sent a message to someone who should be able to help you. I don't know when they'll be available, but the thread has been bumped up.
    chronicracer likes this.
    Jun 2012
    Okay thanks. I read up on captain throwbacks root and s-off for hboot 2.18 and it said if I wanted root only and to install custom roms I didn't need it. But I know i need a custom recovery to flash super user. I want to only use bootloadwr since I have no way of usb. Really hope someone can help me.
    Jun 2012
    Anyone else got ideas? Would be greatly appreciated
    Jun 2012
    Still no help...
  1. Recovery of Pictures?
    By nia796 in forum LG Ally Help
    Last Post: 02-22-2013, 01:08 AM
  2. Need Help Rooting/Recovery Use
    By chronicracer in forum Android Forum
    Last Post: 06-20-2012, 01:13 PM
  3. ClockworkMod Recovery for Captivate
    By moosefist in forum Samsung Captivate Hacking
    Last Post: 02-24-2012, 09:51 AM
  4. Hexamob Recovery Pro
    By wicked_attdroids in forum Sony Xperia Play
    Last Post: 07-19-2011, 05:44 AM
  5. Recovery Mode
    By suntech in forum LG Ally Help
    Last Post: 11-27-2010, 11:50 PM
bootloader only says parsing
captain throwbacks root method for 2.18
hexamob recovery pro free download
hexamob.com/rooting.html
hexamob.com/rooting.html droidx
rooting not detecting pc36img hboot 2.18
rooting says parsing
used htcdev to unlock evo 4g but still wont flash image
