I Can't Seem to Get Any Sound Notifications
This is a discussion on I Can't Seem to Get Any Sound Notifications within the Rescue Squad Help forums, part of the Android Rescue Squad Support Forum category; Hey. I own a new Samsung Galaxy S3 and I can't seem to get any sound notifications when I am being texted. I have checked ...
Results 1 to 10 of 20
Thread: I Can't Seem to Get Any Sound Notifications
    Android Lurker vuzev's Avatar
    Jun 2012
    Hey.
    I have checked the volume in the "Settings" menu, but they are all at max. I don't know if it matters, but I believe the phone is not rooted. I truly need help on this one, I'm going crazy having to check my phone once every 5 minutes for new texts.
    My closest assumption(but I may be very wrong) is that this all happened when I used GoSMS pro instead of my normal message app and selected something that would only allow notifications for texts from GoSMS, but I uninstalled GoSMS in the meantime, so I can't really tell.
    I'm sorry if this should be in another section, I'm just gettin' desperate with this thing. Help would be much appreciated.
    520 times
    Hello vuzey - welcome to the forum!
    Sorry to hear you're experiencing problems, but if you hold on for awhile, one of the Rescue Squad guys will be by to give you a hand.
    197 times
    FurryVarmint
    Are you using a sound on the SD card or internal memory? If it's on the SD card, try pulling the battery and reseating the SD card firmly but gently and see if that solves the issue.
    to the forum!
    Why aren't you sure if the phone is rooted?
    DO NOT WRITE IN THIS SPACE
    Jun 2012
    I'm sorry, but what do you mean by "using a sound"? And I don't have an SD card.
    Because I don't know the definition of a "rooted" phone.
    197 times
    FurryVarmint
    If you got the phone from an individual there's a possibility, then, otherwise it's stock.
    Using a sound as in picked a sound file. If you don't have an SD card, well, you should, but that means the fix I offered won't work.
    Try picking another sound file to use as your notification and see if the problem resolves. If so, try switching back. If not, I'd take it back to where you got it and ask for a replacement unit.
    Android Sr Member Frederuco's Avatar
    Sep 2011
    /EARTH/USA/NC/
    52 times
    frederuco
    Also, go into Settings - Sound - Volume. There should be 3 sliders, the middle one is the notification sound. Make sure this is not all the way down.
    TransformerForums - Administrator
    AcerTabletForum - NexusTablets - AndroidTablets - Super Moderator
    Android.net - TransformerForums - Rescue Squad
    ASUS Transformer 16GB with Keyboard Dock - Cornerstoned and ICS-ified
    iP*one 4
    Just once I want someone to call me Sir without adding you're making a scene.
    - Homer Jay Simpson
    Android Lurker heyitssupergirl's Avatar
    Jul 2012
    Quote Originally Posted by vuzev View Post
    Hey.
    you have probably already figured this out but I'm posting this for others who may be searching for an answer.
    swipe down the status bar, scroll to the side to highlight the notification icon that should be all
    Android Lurker DroidToon's Avatar
    Jul 2012
    Quote Originally Posted by heyitssupergirl View Post
    Unfortunately that's not necessarily the answer,but may be in this case. I'm not new to android or the galaxy series, I'm not getting notification sounds for messages either, I can assure you my notifications are turned on.
    You are not the only one OP.
    I took my phone back for this problem and my new one is exactly the same, default whistle still set as tone,never changed it from new and gosms been nowhere near this phone.
    Sent from my GT-I9300 using Tapatalk 2
    Android Lurker andycharmington's Avatar
    Jul 2012
    I'm having the same problem with my S2, I get all notification sounds except for SMS. I bought it new, haven't rooted or jailbroken it. I've checked the notification volume, tried using different sounds, restarting, updating firmware & software, and there isn't a notification icon in the top menu. Any ideas, anyone?
    197 times
    FurryVarmint
    Have you tried a 3rd party messaging app like Handcent?
    to the forum!
  1. no sound for facebook notifications.
    By ctfcpowelly in forum Samsung Galaxy S2
    Last Post: 09-11-2011, 10:42 AM
  2. Replies: 8
    Last Post: 07-24-2011, 10:41 PM
  3. Notifications
    Last Post: 12-17-2010, 11:21 AM
  4. No Sound from Phone's speakers, but sound from earphones?
    By lalaworld123 in forum Samsung Captivate Tech
    Last Post: 10-25-2010, 05:40 AM
can't hear my notifications
can't hear my text notification on samsung s6
can't hear notifications on android
cant hear some notifications
cant not hear whatsapp notification
i can't hear my notifications
i cant hear sound notifacation fron text
i cant hear text tones on samsung
ringtone for go sms
samsung my notification is on but cant here
why can't i hear anything when my notifications are going off on my android
why can't i hear my notifications
why cant i hear my notifications on my samsung galaxy three
why cant i hear my notifications sounds
why i cant get notification sound on my cell phone
